Can a magnetic shaft generate current flow in a rotating magnetic field?
A rotating shaft in a magnetic field can indeed generate current flow, but it does not need to be made of magnetic material; any conductive material suffices. The shape of the shaft affects current distribution, with long, thin cylindrical shapes producing minimal circulating currents. The discussion highlights that using iron, a magnetic material, versus stainless steel, a non-magnetic material, primarily impacts mechanical properties rather than electrical ones. Leakage currents can occur in both types of materials, but the differences in their electrical behavior are not significant. The conversation also touches on the possibility of using non-magnetic materials like brass or fiberglass for shafts.
kranth90
If iam using a magnetic material as a shaft. The rotating shaft in a magnetic field can cause the flow of current? resulting current flow in shaft?? please clarify me...
The shaft doesn't need to be of a magnetic material, any material that conducts electricity will do. Unless your shaft is an odd shape, there should not be much to worry about. A long thin solid metal cylindrical shape spinning on its longitudinal axis won't have much circulating current. If the shaft were made of layers and strips of a conductor separated by an insulating material in a really strong field this might cause problem voltages and currents.
Do you have an unusual application in mind?
Thanks for your valuable reply. whatever you said is good but really i have a different thought please clear me what the major differences when i use the shaft materials as iron & Stainless steel.
They would have quite different mechanical capabilities, but I can't imagine the electrical differences (if any) would be significant in this respect.
can i define iron as a magnetic material & ss as a non magnetic material ? If so What about the leakage currents condition in shaft Materials of both magnetic & non magnetic materials?
Please answer with patience don't think as foolish bcoz i m poor in this...
Do you have a magnet you can test to see whether it attracts one of your kitchen SS knives?
A shaft could be made of a non-magnetic material such as brass, or fibreglass.
It seems that I'm not going to have my question answered?
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
