Shear Thickening Fluid (in plastic)
Shear thickening fluids (STFs) are being explored for their potential in creating materials that exhibit rigidity under sudden force while remaining flexible under gradual pressure. The discussion focuses on integrating STFs with molten plastic to achieve these properties, particularly for applications like bulletproof vests. There is uncertainty about whether the plastic would retain the shear thickening characteristics after solidification. The conversation highlights a need for more information and research on the effectiveness of this integration. Further insights or findings on the topic would be valuable for advancing the discussion.
treeinthewood
I have been looking into shear thickening fluids and how they are used with Kevlar for bullet proof vests. I am considering alternative uses but have limited knowledge on the subject. I would like to create a rigid solid that becomes harder and less flexible when a large force is suddenly applied but is more flexible and elastic when force is slowly applied. If the stf was added to molten plastic and then left to solidify would the plastic contain any of the properties of the stf?
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
