Sheet Metal Joining: Crimpable or Snap Fit?
  • Thread starter Thread starter DylanB
    Metal Sheet metal
For assembling two sheet metal parts, crimping and snap fit designs are being considered. There is a lack of established snap fit designs for sheet metal, particularly for aluminum sheets around 1/32-1/16" thick. The discussion includes the possibility of creating crimpable flanges and using a crimper to fold and secure the edges. Insights from experienced sheet metal mechanics may provide practical solutions for these joining methods. Overall, exploring both crimping techniques and potential snap fit designs could enhance the assembly process.
DylanB
I'm looking to assemble two sheet metal parts (in the manner a bit like joining two halves of a box) in a simple manner that is either crimpable or some sort of snap fit. I have not seen any snap fit sheet metal designs and I wonder if there is any sort of standard practice (the aluminum sheet metal will be ~1/32-1/16" thick. Otherwise, is there a good way to create crimpable flanges in order to join these parts?
Can the parts be run through a (stone-age) crimper in which the edges are progressively forced into compliance and folded and mashed? My father is a retired sheet-metal mechanic and I have build a lot of stuff over the years just cadging stuff from him and using his tools.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
