Cheap Static Correction Measurement for Dog Shock Collars
A cost-effective method for measuring static correction in dog shock collars is not readily available, as traditional techniques involve high voltage probes and oscilloscopes, which can be expensive. Shock collars likely use an AC high voltage waveform rather than a static shock, complicating measurement since conventional voltmeters may not accurately reflect AC signals. Observing the dog's reaction can help determine the type of current; if the dog freezes upon receiving a shock, it indicates DC, while a lack of reaction suggests AC. Extensive research on this topic exists, particularly from pioneers in electro-physio-psychology. Understanding these measurement techniques is crucial for accurate assessment of shock collar effectiveness.
flymac1
Is there a cheap way to measure static correction on a shock collar for dogs?
Thanks in advance,
Mac
The standard way would be to use a high voltage probe and an oscilloscope. Not exactly a "cheap" way, though. BTW, I'd think that the shock collars probably use an AC high voltage waveform, not a "static" shock. Guess I'll google/wiki them if I have time to see how they work...
I suppose AC would be more difficult to measure than DC, since hooking it to a conventional voltmeter, the needle would not deflect much.
To determine AC or DC, if u happen to see the collar being used, does the dog freeze everytime the electric shock is given? If so, it is DC, for DC will cause muscles to contract. If not, then it's AC.
There are extensive research articles published on this
subject that will tell you everything you need to know
about this kind of measurement technique.
They're recorded under the research works of
Doctors J. Mengele & S. Milgram, pioneers
in their fields of electro-physio-psychology.
Also of note may be the quantitative research of
Doctor I. Pavlov, and the seminal qualitative
analysis of Doctor Marc Bekoff.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
