Shopping advice: Solar battery charger and power supply
The discussion focuses on finding a solar battery charger and power supply for a timer that operates on 2 AA batteries at approximately 3v. The user is experiencing issues with rechargeable batteries not holding a charge and seeks a pre-made, weatherproof solution that can maintain consistent power without the need for frequent checks. Suggestions include using a 4V solar panel with a diode or a 5V solar charger paired with a buck converter to step down the voltage. The user is also exploring options for weatherproofing and has ordered a solar charger and buck converter to test as a potential solution. Overall, the conversation highlights the challenges of finding suitable solar power solutions for specific voltage requirements.
puf_the_majic_dragon
I'm sorry if this isn't the right place for a shopping question, but I'm not sure where else to go for advice.
I got a https://www.amazon.com/dp/B0094KM4VK/?tag=pfamazon01-20 on sale and the unit is great, but the batteries don't hold a charge very well, especially when using rechargeables - it can register low batteries after only a week. I'd like to rig up a solar panel to the timer that will keep the batteries charged and reduce or eliminate the need for me to check on it every few days.
The timer runs on 2 AA batteries, ~3v. Does anyone know of an existing solar charger & 3v power supply that I could use to run this timer?
What I'm looking for is a complete integrated solution that is weather proof and fairly inexpensive. I'd like to find an existing solar power supply that charges its own batteries and regulates the voltage to an independent 3v load. Something I could just mount on the wall and run the wires to the timer and be done with it. Of course, if I do a search for anything "solar charger" or "solar power supply" related, I'm inundated with cell phone chargers (which are all ~5v).
I don't really have the time right now for a DIY project and anything I build would not be very weather resistant. But if there's no premade solution, then I can probably sort it out. This device from adafruit would be good, except that it's "some assembly required" and its output is ~6v and I need 3v; adding a step-down to drop the voltage would just add to the cost and complexity that I would rather avoid.
What kind of batteries are you using? If you just use good alkaline AA, they should last a few months. Maybe your rechargables are at end of life. Are they NiCad?
The adafruit controller you linked to is made to charge a single 3.7V lithium cell, which won't really help you.
You could use the adafruit to a 3.7V lithium and the follow it with a linear 3.0V LDO regulator. It's not power efficient, but it is simple.
(but not water proof either).
Sorry, but I don't have a better answer.
I'm using li-ion AAs. I think part of the problem is most rechargeable batteries list at 1.2v rather than the 1.5 that the timer would get out of alkalines, so it thinks the batteries are deader than they are. It said battery "low" on Saturday so I replaced them and checked the old ones and they still register at full charge ~1.3v. Might also be some chemical differences in how li-ions discharge compared to alkalines.
The problem with just hooking up a solar charger to some batteries and running the wires in a cheap DIY is the lack of voltage regulation and the constant charging/discharging on the batteries. NiCads would develop a memory and die. Li-ions or LiPos or SLAs don't handle overcharging very well - though I've got a spare 12v SLA and a 12v 5w panel doing nothing in a corner.
If I expect the batteries to last, I need a charger with charge protection. If I want consistent power to the timer, I need a power supply with voltage regulation. Instead of trying to put all that together myself, it makes sense to look for a pre-made single unit. I know devices exist in 12v and https://www.amazon.com/dp/B00EM7WN16/?tag=pfamazon01-20 (i.e. for wilderness cameras) and 5v (cell phone chargers) so I'm hoping someone knows where I can find one that does 3v out of the box. I'm just not having any luck finding one.
I did find a https://www.amazon.com/dp/B008BHAOQO/?tag=pfamazon01-20 that I could use to step down a higher voltage to 3v, and it's small enough form factor I think it could fit inside the battery compartment of the timer, with a little modification to the battery cover. So if I'm unable to find a pre-existing 3v system, it looks like plan B might be a $15 5v solar cell phone charger and that buck converter. Bucky might put off some waste heat, but 5v-3v shouldn't be enough to worry about.
But in any DIY case, I still have to figure out weather proofing :/
Can you point me to some 1.5V rechargeable lithium cells?
I've never seen 1.5v lithiums.
Since I haven't had any success finding a 3v complete setup, I just ordered a https://www.amazon.com/gp/product/B005ZSVZRY/?tag=pfamazon01-20 and that buck off Amazon. We'll see how much trouble I can get myself into over the weekend. Cheap charger, buck converter, and 2 3ft USB cables ~$20.
I'm still open to suggestions on weather proofing.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
