Should Electric vehicle be banned?
92 replies · 17K views
sr241 said:
can you explain? is nuclear waste doesn't produce harmful radiations and uranium is considered as rare Earth materials
Nuclear waste is sensationalized due to a general public lack of knowledge as to radiation, its effects, and mitigations. Compared to other forms of energy generation, nuclear is near the top of the list for cleanest, and at the top of the list IMO for "power of the future."
Additionally, Uranium is definitely not going to run out any time soon.
"Economic uranium resources will last for over 100 years at 2006 consumption rates, while it is expected there is twice that amount awaiting discovery. With reprocessing and recycling, the reserves are good for thousands of years."
- http://en.wikipedia.org/wiki/Uranium#Resources_and_reserves
sr241 said:
but there is lot of potential in waste energy recovery in engines. many new rotary engines from independent inventors implements it.
Wankels are generally inefficient IC engines without very large turbochargers, due to their relatively low compression ratios. If an IC engine is going to make it into the future, it will be a turbodiesel due to its high compression ratio (hence higher efficiency than most IC's) and ability to utilize a wide variety of fuels.
sr241 said:
you think hoaxes are pulling Mazda RX8(Wankel) and your lawn mover(quasi turbine engine), chain saw( again rotary) and some air crafts.
Yes the RX-8 uses a Wankel, but it's really more of a technology stunt than proof it's the engine of the future. It burns oil, needs tons of revs (9000+) to get any significant power, and gets poor mileage compared to "standard" 4-cylinder engines.
Wankel powered chainsaws, lawnmowers, and aircraft are generally rare, and have comparable (or worse) performance characteristics than similarly sized 4-stroke engines. They aren't engines of the future, period.
There might be a niche for novel engines in say hybridish Smart-car sized vehicles where a 500-900cc engine generates electricity directly and the wheels are always electric drive. Then you don't have to worry about revs or torque or need crankshafts and gearboxes.
Not sure what you would call them but designs like a Deltic where two pistons operate together without a cylinder head have some advantages.
There are other ways to increase efficiency like implementation of constant volume heat addition. it will increase efficiency and power at the rate of 50% . if you have seen PV diagrams and know about time losses in piston engines you will understand this. new engines like Anyoon rotary engine implements it without any mechanical complexity, it also implements Atkinson cycle (used in Prius) without any additional mechanical system. this new engine has leak proof 100% effective 3D sealing system, newly developed for it.
[PLAIN]http://7250345801171461223-a-1802744773732722657-s-sites.googlegroups.com/site/anyoonrotaryengine/pv-diagram/PV%20Diagram.jpg?attachauth=ANoY7cq5IHPVyneUMoJi6WCztIfiRQwkBUBVyrBBfnGqUDVnIJ-AItdE3NvT623LR4Xh5COX4Nrs9r-KEA6uiFVjDNsmnRVJHt685MaSgVz9ysLWhx4ZMhgXuXWe1sQLfkdVW3aq8z2pnw6s06Mx5BB4JHydwZe4Ijc9Tn4YaWaDlBXQrEvWT5vctqoua34E9gH6plJmzvVVXHDKb316Wd7ScfySO5Orampx0pf1fiVzZcz_3VfAYUw%3D&attredirects=0
Topher925 said:
NOx emissions with DISI engines are not low, they are extremely high. So high that they are not even close to being able to meet US emission regulations. Its not only NOx, but also HC and soot emissions as well. DISI engines are extremely harmful to the environment (as of today) as far as automotive engine technology goes so to have a country with as many cars as the US does would have a significant negative impact on the environment.
Diesels aren't used so much for similar reasons (also cost) although they have gotten a lot better. They're still not as clean as their gasoline counterparts, especially at high loads, but emission production is steadily improving.
Are we talkign about the same thing here GDI (direct injection engines)? If we are then Europe has managed to make them work. Take a look at VW new range of FSI engined cars, the emissions are all within euro 5 (I think it is now) regulations.
Granted they have more NOx emissions than a standard petrol engine, and the standard pertrol has no particulate but CO2 and unburnt HC are both lower. But the thing about GDI is that they allow for more powerful units in smaller packages, that's where you get the efficiency savings.
Thats why emissions from FSI units are lower per km traveled when compared to a standard injection engine, it allows higher boost pressures and more downsizing.
My mk4 gti is the 1.8T version and puts out 150bhp, the modern 1.4 TSI puts out 158bhp and less emissions. All thanks to more boost and FSI.
So making it like a diesel then...
Which is precisely what car makers are doing.
His graph is also totall crap, the cycle simply won't work like that. What his graph is showing is that all the fuel is burned INSTANTLY. As volume on that graph can easily be substituted for the rotary equivilant of crank angle. There is a finite burn time for fuel, it can be made to be incredibly small, but it's impossible to be instant.
Atkinson cylce is fair enough, there are gains to be had there.EDIT: If you don't mind me asking, what do you do for a living? As you are seeming arguing using only that site as a reference, and thus are arguing from a flawed position.
actually in Anyoon engine sufficient time is given for constant volume heat addition. about 30 degrees of rotation are given where volume of combustion chamber is remained same during combustion takes place. only 30 degree is required versus 90 degrees in piston engine for complete combustion since in Anyoon engine volume of gas during entire combustion is very low or equal to the volume of combustion chamber.
sr241 said:
can you explain? You think there is no loss in transmission of electricity from power station to home.
No, it isn't that there is none, it's just that it is very small and doesn't follow that it increases with amperage. Why? Because when people need to send higher amperages they use bigger wires!
so why don't you use engines in cars
Huh?
Anyway, with car engine efficiency, once you've added a turbocharger and a heat recovery steam cycle, there really isn't much left. And those are old technology - they just aren't used because it costs money to put them in the car and until now, you'd never get that money back in fuel savings.
MechE said "sensationalized", I'd go so far as to say hoaxed. The nuclear waste issue is in essence one big lie perpetrated by the radical anti-nuclear power fringe in the 1960s and 1970s that now most people believe. The fact of the matter is that more than 95% of supposed nuclear "waste" is recyclable. When you are ultimately done with it it is far less radioactive than when dug out of the ground, except for that few percent. What's left can easily be stored: unlike pollution from cars and coal plants, which cannot be stored with existing technology.
Air pollution mostly due to cars and coal power plants kills about 20,000 people in the US every year. Except for the rare industrial accidents (ie, construction workers falling off ladders, etc.), nuclear power has never killed anyone in the US. And no one unassociated with the production of the power.
There's some, but not as much as you think. And those "independent inventors" either just don't know what they are talking about or are hoaxsters. The one you linked is such a hoax as it included obviously bogus efficiency numbers far above the theoretical maximum for a simple combustion cycle.
The RX8 engine isn't anything special - it is the ones from "independent inventors" such as the one you linked that are hoaxes.
since this is physics forum you need theoretical support for what you say. you can not blindly say crackpot when those inventions have sound theoretical support
Lol, no. Burden of proof is always in the court of the one making the extrordinary claim. Fortunately for an "inventor", proving the claim is easy: they just have to submit their engine for testing. That they don't should give you a clue that they haven't really invented what they say/think they have. Besides which the "sound theoretical support" on that site contained laughably silly points, such as one place referencing a efficiency number using 2000C as the high temperature.
How did I not spot this before?
1. You have been harping on about efficiency. Let's take the only true pistonless rotary you mentioned the RX8 Wankel.
Has a huge surface area to volume ratio vs a piston engine, meaning a higher amount of heat transfer from the combusion chamber to the block. This reduced efficiency. Doesn't seal as well as a piston engine. You get fresh charge seeping into the adjacent chamber and going stright out the exhaust. It also means it burns oil. Has a low compression ratio which reduced efficiency.
The upshot of this is that it gets about 15-25mpg. The most I have seen from the 238bhp version is 27 on long distance cruising. On the plus side it's light, it goes like stink and doesn't vibrate.The difference between the Wankel rotary and this new thing are:
The Wankel desn't make excessive efficiency claims based on an overly optimistic look at a pv diagram.
The Wankel has proved to work on extended driving this other one hasn't, although the seals are still something that requires constant maintainence.
The Anyoon's claim of 100% sealing, when there is no evidence of a practical seal test is simply annoying. I can tell you something for nothing, a rubber polymer pushing a metal seal on something that is close to combusion temperatues will not last for very long. There is a reason pistons use metal-metal seals.EDIT: That Anyoon engine will certainly run if it's built, I'm not saying it's a total crock of faecal matter. Just it really won't do what the inventor says it will.
for sealing Anyoon uses flourosilicone rubber ( can withstand above 400c) which is used in space shuttle nozzle bushes. and typical piston ring temp in engine is 220C refer "Engineering Fundamentalsof the Internal Combustion Engine byWillard W. Pulkrabek chapter ten page315"
So there is no question of lasting of seals
what is wrong with calculating Carnot efficiency between 2000k and 300k it is said 85% if you have new method for calculating Carnot efficiency please give me I will send it to laughter therapists (they will use it for those having difficulty in laughing).
No, we are not. GDI usually refers to just directly injecting fuel instead of having a port injector before the intake valve(s) and is still essentially the otto cycle. DISI usually refers to stratified charge combustion and is more similar to the diesel cycle. I know, its a stupid and confusing naming convention.
As far as GDI goes, just about every major auto manufacturer has their own form of it. Ford has their EcoBoost, and a lot of the japanese companies like Mitsubishi and Nissan have been selling cars with GDI since the 90's. While GDI does provide a little better fuel economy and greater power density, it still mostly operates around the stoichiometric region and has some differences compared to DISI.
DISI, or stratified charge combustion engines, are unthrottled and rely directly on the amount of fuel injected to control power output. They typically operate at very lean stoichiometry and have very high compression ratios. Because of this they can operate at much higher efficiencies than your typically GDI engine. The problem is that since they operate at overall very lean conditions, have higher compression ratios (more heat), and the charge is stratified, they generate considerable amounts of NOx and HC. While the HC's can be removed with filtering the NOx is very difficult to get rid of. You can't just pass it through a 3-way cat because of the amount of oxygen that's present in the exhaust stream.
That explains it - I though DISI was the same as the spark-less gasoline in a diesel cycle engines. Those DO have better efficency and lower NOx
Let me add my 2¢ and stir the pot a little bit.
First, I'm a big fan of the IC engine in personal vehicle and I don't believe it will be efficiently replaced soon. Although, there is a lot of propaganda to make it the devil's machine. IMHO, the way it is overused is more responsible of the problems we have.
The problem with any engine (no matter the type) in a vehicle is to store the energy efficiently. Mechanically, you can wind up a spring, speed up a flywheel, compress a fluid, etc. Electrically, you need a battery. But no matter how you look at it (volume, mass, safety, cost, power, etc.), storing it in a liquid fuel that you will burn is pretty hard to beat.
Electricity in a vehicle, I see it used appropriately in two ways:
The first one is by coupling an IC engine to an "electric" transmission, i.e. a generator and motor(s). Although, weight could be a factor, the power transmission efficiency is usually better than any mechanical mean and the fact that it is an infinitively variable transmission means that the IC engine can be used at its best BSFC (for the hp needed) all the time. The locomotives use that system and I always wondered why it was never implemented in a personal vehicle (I'm sure there are drawbacks I'm not aware of, but with today's EV, I think it is a pretty similar technology).
The second way is railroad electrical vehicle. Electricity is only an advantage as long as you use the power as you produce it. If you have to store it (thus using a battery), it looses all of its appeal. The only way you can do that with a vehicle is by knowing the path of the vehicle such that it can be followed by a wire, hence some kind of rail system. Of course, this can only be used for mass transportation or merchandise. If society have to invest in electric vehicles, this would be my first choice. Removing all of those trucks crossing the country or building high speed trains replacing gas-guzzling airplanes would be a better use of the billion$ invested in the development of personal car batteries which, in the end, are still no match to a gas tank in so many ways, and nobody knows their environmental impact yet (which may be just as bad as air pollution). It is easier to change a few commercial fleets and the way they do business, than changing millions of individual minds. And the end effects on air pollution will probably be similar without the battery problem.
Now, without endorsing everything he said, I would like to bring some defense to sr241 (He seems lonely in its corner!).
First, I see a lot of people giving excuses for EV concerning their high cost or lack of practicality by saying that development is underway and all problems will be solved in the future. To me that sounds like "magic thinking" where there is a way that exists which has no drawback and only advantages. I've never seen this in any engineering field and if such a way exists, with all the time and money spent on EV, it would have been obvious by now. It is not.
And, if we assume that R&D is the solution to EV, how come we don't assume that it would be the answer to make a better rotary engine? It is easy to say that the only viable rotary engine is the one from the RX-8 and that it is not as good as traditional piston engines, but a lot more R&D went into the last one. A LOT more. Even EV have a lot more R&D than rotary engine. But, when you look at the development of the Wankel engine since its debut, a lot of technical progress has been made (especially in sealing), mostly due to Mazda's effort. And saying that they have high rpm (so what? They need a gearbox anyway) or that they need a turbo because of their low compression ratio (Compressing in a turbo or in a cylinder, what's the difference?) as drawbacks are just ridiculous and non-founded statements.
Finally, although I'm no expert on the subject - and neither a radical opponent - when talking about nuclear energy being safer than anything else, I'm a little skeptical. Never heard of Three mile Island or Tchernobyl? But I'm sure there are good excuses and it will never happen again.
It seems that there is not only sr241 that says stuff based on dreams on this thread. It's not because a theory is popular that it is true. You have to keep an open mind to make a discussion viable.
It's mainly done in a locomotive because of the difficulty of making a transmission that has enough torque to start a 1000 ton moviong train and also move it at 125mph. Fully electric locos are mainly because of the much higher power density you get with electric motors. An intercity high speed train is 5MW, about twice the power of a diesel loco but the motors fit under body. The maintenance is also a lot lower as well as noise, smoke etc.
My bet is that for small cars (like Smart) a small constant speed diesel + battery + electric motor in wheel hub is likely to be a common solution. Just because of simplcity and space.
Even with perfect sealing a Wankel engine is fundementally limited in the compression ratio it can achieve just form geometry. A piston engine is only limited by the strength of the metal so you can make small economical diesels with 20:1 compression getting half that in a Wankel is real feat of engineering.
Yes piston engines have had a lot longer R&D, but all that R&D has also benefited rotary engines. Mazda weren't exactly workign with stone age tools to design their engine.
With all of its thousands and thousands of ingenious improvements over the past century, all working together and made inexpensively, the internal combustion engine in its current form is an absolute marvel to behold in my view. Today's engine is a marvel because of all of that colossal ingenuity and effort required to make it workable. I say required because setting all of the century's improvements aside for moment and looking only at the problem of individual transportation from A to B, and seen only as a self-contained engineering project, the internal combustion engine is a mistake, a disaster. No I'm not talking about all the environmental issues. I refer only to the engine itself and what's required on an auto-mobile.
So from the engineering design from scratch, let's say one starts from some horsepower goal that provides some tractive power, derived from a vehicle size and speed. Ok, from there via considerable effort we work out how much hot gas needs to do how much work on some pistons and so on, how to convert that to rotary motion via crank shaft, etc, and we end up with the basic engine block and its several hundred parts, many of them moveable. That in and of itself is no small achievement.
Am I nearly done? Hardly. Because the thing has an inevitable low efficiency as compelled by thermodynamics, I have to add a substantial heat removal system. Liquid cooling is required, and an extensive and large heat transfer radiator. As the engine's power and torque output are so dependent on operating point (RPM), in fact with zero power at zero RPM, I have to design a complicated power transmission device, a complicated fuel - air mixing system (along with the fuel pump), and an auxillary starting system with a temporary torque within in an order of magnitude of the primary engine itself. The exhaust gasses containing much of that unavoidably wasted energy are also toxic requiring an exhaust system. The entire thing is a very difficult mechanical noise vibration problem due inherently to the piston displacement fundamentals (that will take decades to master).
As it turns out all of this is worth the trouble because of the great utility of the automobile over horses, and because all of the combustion engine's waste and snowballing patches on top of patches are made possible by the high specific energy of petroleum. I grant all that. Still doesn't change my view that the combustion engine is twisted joke of an engineering solution to the problem of moving things around, as compared to elegance of the electric motor.
Just saying. :smile:
The only thing holding electric vehicles back is energy storage. Batteries aren't a very good solution because the take a long time to charge, are heavy, and don't have particuraly good power density compared to gasoline or diesel. People are hopeful that supercapacitors will help some of that, but I don't think they will be able to reach the energy density of gasoline any time soon.
Of course right now the hydrogen economy isn't much better because you have to carry a large high pressure tank of hydrogen, also not close to the energy storage capacity of a gas tank. Liquid storage mediums for hydrogen are an interesting concept, we'll see how they turn out.
I'm not understanding this obsession with rotary engines? They are in the end an internal combustion engine, nothing special. If they were capable of higher compression ratios they might have a chance, but they just aren't (9:1 compression is a real challenge, diesels hit 20+ without trouble).
What "R&D" are you hoping to do on a rotary engine that wouldn't benefit any number of standard piston engines?
You quote three mile island as a "terrible" disaster, so tell me- how many people died as a result of the Three Mile Island accident? Chenobyl is known to many as the worst civilian nuclear accident ever, do you know how many people died as a direct result of it? Perhaps you are expecting hudreds of thousands of people, even millions? Would you believe only 30 people died as a direct result of the original Chernobyl accient, and perhaps 4000 total due to long-term radiation effects? No civilians have died in the United States due to exposure to a nuclear plant. NOT ONE!
Now compare those numbers to the number of people die mining coal (the United States averages about 30 deaths/year), or the number of people that die in the oil industry each year... The safety record of nuclear power is impeccable compared to these values, you've just never bothered to ask because you have been subject to anti-nuclear propganda which is not based in FACT.
If we recall the goal is transportation, not just to store energy, then we see that other issues like the efficiency of the motor are also important.
At the moment, the energy specific density comparison is about
  • 60:1 energy density ratio, gasoline to rechargeable battery specific energy. Twenty years ago it was 50% worse.
The electric drive train is roughly 3X more efficient than the combustion engine so we have about
  • 20:1 'transportation' specific density ratio, gasoline fuel + combustion engine to e-motor + battery per unit mass
Now the average plastic/aluminum fuel tank on a light duty vehicle is not very big, say, 15 gallons, because such vehicles don't need to travel 1500 miles on one fuel load. In the case of an electric vehicle when the fuel pump, radiator, exhaust, starter motor, transmission largely disappear there's ample room for the energy storage device (battery) to get 5X heavier (which it does in the new EVs), which gives us
  • 4:1 vehicle range ratio, gasoline + combustion engine vehicle to electric vehicle
which is about where we are today - average car can do nearly 400 miles, average EV 100 miles. Start adding to that story the ability to charge over night in your driveway/garage/parking lot so that regular trips to a fuel station disappear, and the EV begins to look like an attractive way get off oil imports and reduce pollution.
Frankly for general use we should get to electric vehichles as soon as possible. It's likely to be viable in about 10years or so.
Just like the car replaced the work horse. And horses were used for pleasure. The EV will be the work horse of tomorrow, leaving petrol engines for pleasure. It can't come quick enough so there will be more petrol for me to cane around the country roads with.
I am a petrolhead, I love motorsports and everything car related. I think a well designed engine is a thing of beauty.
I am also a realist, we can't continue to burn oil at the rate we are. I also understand the concept of diminishing returns. The IC is 120 years old, it's coming to the end of it's development life, there is only so much you can get out of a concept.
Currently there simply are no drawbacks for electric vehicles apart from:
infrastructure.
energy storage.
cost.
Thats it's, the power generation, and delivery systems are both more efficienct for moving you along the road. Not only that but the characteristics of an electric motor make it acutally better than an IC engine for general driving. They have 100% torque from 0 RPM up to about 80% max 'revs'.
Oh and everyone will have to relearn the green cross code, as you can't hear them coming.
Rotaries have their inherent flaws (I didn't say it was the only viable one, I said it was the only pistonless one he mentioned). They will NEVER compress as well as a piston engine and they will NEVER seal as well. They are clearly superior in specific power though.
So it depends what you want. If you want a massivly powerful engine from a very small light package, go rotary. If you want fuel economy and efficiency, dont.
Conversely EV will have their flaws too. Suc has hot battery packs, and the stuff listed above. But the ir potential outweighs that of the drawbacks.
Ever heard of France. 80% nuclear generation to the tune of 425TWh. They have been operating mostly on nuclear for about 30 years now with only 1 or 2 incidents of note. No fatalities directly caused by it.
It's this kind of knee jerk reaction to the word nuclear tha thas set the world back.
No it's not because its popular that it's true. It's true because it's true. End of.
Saying you should 'ban the electric car' because you should be developing something else it's utterly stupid. It's product lifecycle 101. To be good and successful you need a product or technology on each strange of the cycle. To try to artificially extend one at the expense of a new product with more potential it's simply stupid.
There is a racing idiom: the last of the old will always beat the first of the new, at first.
The "question" exists unitl it is proven with a demonstration that it works as claimed because as other similar engines have demonstrated, it doesn't work as claimed. Really, it is incorrect to say "Anyoon uses" since until it is sucessfully demonstrated it doesn't "use" anything.
There are two obvious problems:
1. The high temp of a combustion engine isn't anywhere close to 2,000 K. The maximum flame temperature (in air) of gasoline is about 1,300k. That gives a maximum Carnot efficiency of 77%, assuming the Th would really be equal to the maximum flame temperature (which it wouldn't).
2. This engine isn't a Carnot engine: Carnot efficiency assumes no losses anywhere, ideal gases, etc., and isn't possible.
No one was injured by TMI. It is a good example of just how safe the nuclear power industry is in the West that despite massive failures, virtually no release of radioactive material happened.
Chernobyl was overblown, but still, it isn't possible in the West: it used a designed banned by the West because it didn't include a safety containment vessel.
Also I've got to say something here. You do realize that the Carnot efficiency can never be reached, right?
The closest 'real' cycle you can get is a brayton cycle for gas engines and rankine for steam cycle. The ideal cylces for these have efficiences way below the Carnot efficiency. When you start adding in real components with isentropic efficiencies <1 it becomes clear that claims of efficiency remotely close to a Carnot efficiency are an utter joke.
This is why people like Siemens and Rolls Royce are spending phenomenal amounts of money chasing tenths (if not hundredths) of percent gains in turbine and compresser efficiency.
As Russ pointed out, 2000k is optimistic for combustion temperatures. Not only that but this is a rotary, so the surface to volume ratio means you are going to be transferring a fair bit of that to the block.
Just a little history note from http://en.wikipedia.org/wiki/Electric_vehicles#History":
Between 1832 and 1839 (the exact year is uncertain), Robert Anderson of Scotland invented the first crude electric carriage, powered by non-rechargeable primary cells.
Electric vehicles were among the earliest automobiles, and before the preeminence of light, powerful internal combustion engines, electric automobiles held many vehicle land speed and distance records in the early 1900s. (...) and at one point in history out-sold gasoline-powered vehicles.
So EV are 175 years old. They were 'replaced' by the 'new and improved' ICE technology about 75 years later, even if they already had all the advantages of low RPM torque and better efficiency over the ICE. A good thing that, back then, nobody said "The EV is 75 years old, it's coming to the end of it's development life, there is only so much you can get out of a concept." or we wouldn't be here having this discussion about your 'new' concept.
People did not choose ICE over EV for personal use just for the fun of it, there were major advantages.
infrastructure.
energy storage.
cost.
Thats it's,
energy storage, infrastructure, hot battery packs, limited range, 'filling up' measured in hours instead of minutes, cost. Oh yah, and you forgot battery performance variation with outside temp (I live in Canada, what can I say).
That's it? These are the ONLY problems to solve? After 175 years of development? You're kidding right? Cost! ... Cost! Whether right or wrong, in today's world, that's the only concern that people have on their mind, and this is a minor drawback? A 100 miles range where you have to plug-in for 1-2 hours to charge @ 80% capacity is a salable concept for an everyday car for the average family? Come on, get serious, you don't truly believe what you are all saying?
With an argumentation like that, I guess the Earth would still be flat.
If I didn't make myself clear, let me correct that: I'm not against EV and I certainly do not want to ban them. Good for us if something good came out of this. Like I said, I think the future of EV lies in railroad development and cleaner air by removing ICE long range carrier (either for people or merchandise), but not for vehicle needed for personal use. Except for some urban people that never get out of the city, I don't think EV will reach the practicality needed (for a fair price) by the average family.
It's like everyone has a 5-seater even if most of the time there is just 1 or 2 people in the car. But, once in a while, you need the 5-seater, so that's what you have. Same thing with mileage range, most of the time, you have enough of 100 miles, but once in a while you need 200 miles (and even more) and that's what your vehicle must be able to do.
IMHO, thinking that ICE is a thing of the past is pure dreaming at this point that can only lead to disappointment.
No so long ago, I was like everybody else: I looked at the numbers for the Mazda engine and concluded that they were no match for traditional engine. Since then, I had to study them a little bit more, and I found them more and more attractive (I didn't say perfect). Even if they achieve the same goal, the challenges with a rotary engine versus piston engine are world apart. So, no, you can't use R&D from one to apply blindly on the other. It's a whole other way of thinking.
Everybody seems to be stuck with the CR. Yes, it is a limited factor on the WANKEL engine. But this is not the only form of rotary engine, and some designs can achieve higher CR (I'm currently studying one model that can go up to 50:1). Even so, like I said earlier, you can pre-compress the air. For example, a two-stroke diesel engine has no compression stroke and air is compress by an external compressor before entering the cylinder. And please, don't try to figure all the flaws and saying that it will never work, this is why I'm saying R&D is important in that domain also. Again, not instead of EV R&D, but with it, concurrently. It shouldn't be as easily discarded as you're trying to do in this thread.
Whether ICE or EV, at this point in history, there will be no easy answers and a lot of R&D needed.
flame temperature is not a limit for temperature achievable. even without any flame compressing gas(or increasing pressure without changing volume) will increase its temperature. In Anyoon engine combustion is done at constant volume so maximum temperature can achieved with minimum fuel. in constant volume heat addition pressure is increasing hugely and volume is not increasing this will lead to higher temperature than flame temp. this is a basic thermodynamic fact please refer Ideal gas equation.
where he mentioned this Carnot efficiency in his site he is saying it as a limit and his engines is efficiency is within that limit that's what's his claim.
In my point of view Carnot efficiency is not a limit if we were able to recover all heat that's given we could get a 100% efficient engine. for this heat recovery Anyoon engine uses water injection in expansion stroke and also high expansion ratio.
Constant volume heat addition has least surface to volume ratio ever possible during combustion since volume is not changing ( in piston engine volume as well as surface area increase during combustion) and geometry of combustion chamber in Anyoon engine is cylindrical for swirl. Anyoon engine is entirely different from Wankel engine
At that time there was only one advantage: range.
Battery swaps require 60 seconds currently in http://www.betterplace.com/company/video-detail/tokyo-electric-taxi-project-opening/" .
cost.
Cost per mile including vehicle depreciation is about the same as a combustion vehicle with a leased battery.
Battery heater.
just tell me if recover all heat given to system does that gives 100% efficiency. here Carnot efficiency does not hold. for 100% Carnot efficiency you either need T_hot to be infinity or T-cold to be 0 kelvin. if you have theoretical support against the above said then I will appreciate you.
In Anyoon engine he used water injection in expansion stroke for waste energy recovery. He also implemented higher expansion ratio (Atkinson cycle) simply and brilliantly.
What... if you recover all heat from a system. How the hell ae you going to build that? A 100% efficiency means the cycle is reversible.
You seem to be a slighty educated person. Are you seriously saying that a reversible thermodynamic system is possible in reality.
EDIT: I'm not sure if I am just misunderstanding you or something. I cartinly hope I am.
not all the heat of system heat that is given to it. An isentropic system is reversible
Could you please type in full sentences, that actually make sense.
You cannot physically build a reversible system, as it violates the 2nd law. You MUST know this.
in water injection a new working medium(water) is introduced in 3rd stage of cycle. when hot gas and water become in equilibrium inside engine, temperature will be lower than hot gases and pressure will be higher due to phase change of water. so there will be huge reduction in cooling losses . Due to higher expansion ratio these steam and gases can do more work so exhaust losses too will be greatly lower.
It doesn't matter if you introduce a 3rd stage into the cycle or not. There are 6 strokes that use the waste heat to power a steam cycle. That is still not getting a reversible system, meaning that it's not going to get 100% efficiency. There are also water injection engines that spray water into the fuel air mix. This has all been done before.
It's just like the Rankine cycle, you can add superheaters and reheaters, and multipass turbines. But the effective increase on efficiency ISNT LINEAR. You add a second pass, you don't double the efficiency.
You can add all this crap to the engine that you want, you will not get anywhere close to the carnot efficiency. In practical t4erms you are adding maxxive amounts of complexity at increasing cost, chasing rapidly decreasing gains.
This is frankly getting bloody ridiculous now. You have clearly glossed over the fact that the inventor made the claim that it would be possible with work to make it 100% efficienct, which goes against a fundamental law of the universe. Now I don't know if that was just a language barrier thing on the inventors part, or he truly believes it. I hope it's the former, as the latter option is very worrying indeed.
