Show 2a=0 is a subgroup
  • Thread starter kathrynag
  • Tags
    Subgroup
Therefore, if 2a = 0, then 2a + 2b = 2b + 2a = 0, which means that (2a + 2b) - (2b + 2a) = 0 - 0 = 0. By the definition of a subgroup, this means that 2(a + b) = 0, so the set is closed under the operation of addition. It also contains the identity element, 0, since 2(0) = 0. Therefore, the set is a subgroup of G.For G = Z12, the subgroup would be {0, 6}.In summary, we showed that the set {a |
kathrynag
598
Let G be an abelian group such that the operation on G is denoted additively. Show that 2a=0 is a subgroup on G. Compute this subgroup for G=Z12.
Well, I started out by knowing that abelian means ab=ba.
The problem should probably be stated like this. Show that the set {a | 2a = 0} is a subgroup of an abelian group G.
Since the operation is addition, abelian means a + b = b + a.
What is a subgroup?
A subgroup is a subset of a larger group that also forms a group under the same operation as the larger group. In other words, the elements of a subgroup must follow the same rules and properties as the elements of the larger group.
How do you prove that 2a=0 is a subgroup?
To prove that 2a=0 is a subgroup, we need to show that it meets the three criteria for being a subgroup: closure, identity, and inverse. This means that when you multiply any two elements of the subgroup, the result will still be in the subgroup, the subgroup contains an identity element, and every element in the subgroup has an inverse in the subgroup.
What is the closure property and why is it important for showing 2a=0 is a subgroup?
The closure property states that when you perform an operation on two elements of a group, the result will still be in the group. For 2a=0 to be a subgroup, it must contain all possible results of multiplying any two elements. This is important because it ensures that the subgroup is closed under the operation and that the operation is well-defined.
What is the identity element in 2a=0?
The identity element in 2a=0 is 0. This means that when you multiply any element in the subgroup by 0, the result will always be 0. The identity element is important because it allows for the existence of an inverse for every element in the subgroup.
How does showing 2a=0 is a subgroup relate to the concept of symmetry?
The concept of symmetry is related to the idea of a subgroup because a subgroup is essentially a smaller group that still exhibits the same properties and structure as the larger group. Symmetry is a key property of groups and subgroups, where certain operations or transformations can be applied to the elements to maintain the same overall shape or structure. In this case, 2a=0 represents a subgroup of the larger group of real numbers under multiplication, where the symmetry is maintained by the inverse operation of division.
