Show EM Wave equation invariant under a Lorentz Transformation
The discussion focuses on demonstrating the invariance of the electromagnetic wave equation under Lorentz transformations. Participants outline the necessary steps, including transforming the variables and applying the chain rule for partial derivatives. A key point of confusion arises regarding the derivative of the transformed variables, particularly how to derive \(\frac{\partial x'}{\partial x}\) and \(\frac{\partial t'}{\partial t}\). Clarifications are provided on treating other variables as constants during differentiation, leading to a better understanding of the relationships between the transformed and original variables. Ultimately, the participants work through the algebra to confirm the invariance of the wave equation.
Antic_Hay
Show that the electromagnetic wave equation
\frac{\partial^{2}\phi}{\partial x^{2}} +<br /> \frac{\partial^{2}\phi}{\partial y^{2}} +<br /> \frac{\partial^{2}\phi}{\partial z^{2}} -<br /> \frac{1}{c^2}\frac{\partial^{2} \phi}{\partial t^2}
is invariant under a Lorentz transformation.
Lorentz Transformations:
x&#039; = \frac{x - vt}{\sqrt{1 - \frac{v^2}{c^2}}}
t&#039; = \frac{t - \frac{v}{c^2}x}{\sqrt{1 - \frac{v^2}{c^2}}}
y&#039; = y
z&#039; = z
Well I know exactly what I'm supposed to do here, transform the equations from x to x', y to y' etc. Then rearrange terms and show that the wave equation with x,y,z, and t is equal to the wave equation with x', y', z', and t'.
I understand the method is to get \frac{\partial x&#039;}{\partial x}, then use the chain rule ( \frac{\partial\phi}{\partial x} = \frac{\partial\phi}{\partial x&#039;}\frac{\partial x&#039;}{\partial x} ), and similarly for t -> t', then a bit of simple algebra and the answer should pop out the other end.
My only problem is that I have no idea what \frac{\partial x&#039;}{\partial x} is...in fact, I do know, since I have been told, that \frac{\partial x&#039;}{\partial x} = \frac{1}{\sqrt{1 - v^2/c^2}}, but I have no idea how that follows from the Lorentz transforms, could someone give me a hint in deriving it?
(My attempt was simply saying \partial x&#039; = \frac{\partial x - v\partial t&#039;}{1 - v^2/c^2}, but then dividing that by \partial x&#039; I'd get \frac{1 - \frac{\partial t&#039;}{\partial t}}{\sqrt{1-v^2/c^2}}, which isn't right...
As you can tell, I'm not really very comfortable with partial derivatives or differential calculus, so I'm probably doing something really silly in that derivation above...
Simply take the partial derivative of x' with respect to x. Same as taking a normal derivative of x' but treat all the variables except x as constants
Ah, that made sense, I knew it would be something trivial, I was just approaching it weirdly.
Great, have the answer now, thanks :)
OK, I thought I had the answer but this but it turns out I don't...
I want to calculate \frac{\partial t&#039;}{\partial t}
So I have t&#039; = \frac{t - \frac{vx}{c^2}}{\sqrt{1 - v^2/c^2}}
The answer is supposedly \frac{1}{\sqrt{1 - v^2/c^2}}
I don't see how this would be...the bottom line is a constant term so looking at the top line alone,
\frac{\partial}{\partial t} t is obviously 1, fine, but I don't see how \frac{\partial}{\partial t} (-\frac{vx}{c^2}) = 0, surely x is a function of t, so we get
\frac{\partial}{\partial t} x = \frac{\partial x}{\partial t} = v so \frac{\partial}{\partial t} (t - vx/c^2) = 1 - v^2/c^2 for the derivative of the top line?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
