Show if its a lin. independent subset
  • Thread starter Thread starter holezch
    Independent
holezch
V = { (x_{1},x_{2},x_{3},x_{4},x_{5}) \in R^{5} : x_{1} -2x_{2} + 3x_{3} - x_{4} + 2x_{5} = 0 }
show that S = { (0,1,1,1,0) } is a linearly independent subset of V.
I don't get it.. it's a set with 1 non zero vector, it's going to be linearly independent? then do I just have to show that it's actualy in V?
thanks
Yes, a set with 1 element is going to be linearly independent. You must verify that (0,1,1,1,0) is actually in V to show that S is a subset of V. Just plug the vector into the equation and see if you get 0.
thanks, I thought I was misunderstanding something.. since it looked to trivial to me haha
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
