Show momentum is conserved in two different frames (relativity)
The discussion centers on demonstrating the conservation of momentum in two different reference frames during a collision between a 2000-kg car and a 1500-kg car. The analysis shows that momentum conservation holds true in both the rest frame and a moving frame at 10 m/s. The equations derived confirm that the final speed of the combined mass post-collision remains consistent across both frames, validating the principle of momentum conservation. The solution emphasizes the importance of consistent notation and clear definitions of variables throughout the calculations.
  • Understanding of classical mechanics principles, particularly momentum conservation.
  • Familiarity with collision equations and mass-velocity relationships.
  • Knowledge of reference frames in physics, especially in the context of relativity.
  • Ability to manipulate algebraic equations to solve for unknowns.
  • Study the principles of momentum conservation in elastic and inelastic collisions.
  • Learn about reference frames and their impact on physical laws in special relativity.
  • Explore detailed examples of momentum conservation in different inertial frames.
  • Investigate the mathematical derivation of the conservation of momentum in various collision scenarios.
Students of physics, particularly those studying mechanics and relativity, as well as educators seeking to clarify concepts of momentum conservation in different reference frames.
Ravenatic20
A 2000-kg car moving with a speed of 20 m/s collides with and sticks to a 1500-kg car at rest. Show that because momentum is conserved in the rest frame, momentum is also conserved in a reference frame moving with a speed of 10 m/s in the direction of the moving car.
Not sure
Let's have the larger (2000-kg) car be mass M, and the smaller (1500-kg) car to be mass m. Car M is traveling at speed v. After the collision, the two cars become one mass (M+m) and its velocity we will call v'.
To an observer on the ground...
mv + 0 = (M+m) v'
v' = MV/(M+m)
To an observer in a moving frame...
M is moving at speed V-v (towards the smaller car, m) and m is moving at speed -v (towards the larger vehicle, M). After the collision, (M+m) is moving at speed v'-v.
M(V-v) - mv = (M+m)(v'-v)
MV - Mv - mv + Mv + mv = (M+m)v'
v' = MV/(M+m)
These two equations are the same, meaning the final speed of the indecent is v' from any observer. Does this mean momentum is also conserved in a reference frame? If I'm on the right track, what good would it do plugging in numbers?
Re-read the question. You need to prove that conservation of momentum in the rest frame implies conservation of momentum in the moving frame. You're also not being consistent with your notation. The v in your first set of equations represents the speed of the bigger car, but in the second set of equations it represents the relative speed of the moving frame.
You're right. I ended up solving the problem. Thanks anyways.
Consider this problem solved.
  • · Replies 46 ·
