Show that the integral of the Dirac delta function is equal to 1
The discussion revolves around the integral of the Dirac delta function, specifically the form $\delta_\epsilon (x) = \frac{\epsilon}{\pi(x^2 + \epsilon^2)}$. Participants explore how to show that the limit of the integral $\lim_{\epsilon \to 0+} \int_{a}^{b} \delta_\epsilon (x) dx$ equals 1. The conversation includes mathematical reasoning and integration techniques.
  • One participant questions how to show the limit of the integral equals 1 and mentions the challenge of applying L'Hospital's rule due to the presence of two variables, $x$ and $\epsilon$.
  • Another participant suggests directly integrating the function and provides a result involving the arctangent function, but expresses uncertainty about the next steps.
  • A different participant argues that the limit should be taken as $\epsilon \to 0+$ rather than $x \to 0+$.
  • Further contributions clarify the integration process and the behavior of the arctangent function as $\epsilon$ approaches 0, noting the limits of the arctangent at infinity.
  • Another participant states that for any $\epsilon$, the integral $\int_{-\infty}^{+\infty} \delta_{\epsilon}(x)dx = 1$.
  • One participant concludes that they now understand how to prove the statement after receiving help.
Participants express differing views on the approach to take regarding the limits in the integral, and there is no consensus on the integration method or the steps leading to the conclusion. The discussion remains unresolved regarding the most effective method to demonstrate the limit.
There are unresolved aspects regarding the assumptions made in the integration process and the dependence on the limits chosen for $x$ and $\epsilon$. The discussion reflects varying interpretations of the mathematical steps involved.
Doitright
Hi,
I am reading the Quantum Mechanics, 2nd edition by Bransden and Joachain. On page 777, the book gives an example of Dirac delta function.
I am wondering how I can show $\lim_{x\to 0+} \int_{a}^{b} \delta_\epsilon (x) dx$ equals to 1. I've thought about using L'Hospital's rule, but there are two variables, $x$ and $\epsilon$, so seems I cannot use the rule directly. I've been stuck in this for some time. Will be grateful if some one can point the direction for me. Thanks.
Have you tried integrating that function?
I've tried integration, and get $\frac{\arctan(\frac{x}{\epsilon})}{\pi}$. However, seems there is still no way out.
I think you shouldn' t make the limit for x-->0+ but for epsilon-->0+.
lightarrow
You need to put two dollar-signs around an equation to render it in LaTex:
\$\$\frac{\arctan(\frac{x}{\epsilon})}{\pi}\$\$
renders as:
$$\frac{\arctan(\frac{x}{\epsilon})}{\pi}$$
You basically have the answer there:
[itex]\int_{a}^{b} \frac{\epsilon dx}{\pi (\epsilon^2 + x^2)} = \frac{1}{\pi} arctan(\frac{x}{\epsilon})|_a^b = \frac{1}{\pi} (arctan(\frac{a}{\epsilon}) - arctan(\frac{b}{\epsilon}))[/itex]
In the limit as [itex]\epsilon \rightarrow 0[/itex], [itex]\frac{a}{\epsilon} \rightarrow \pm \infty[/itex] and [itex]\frac{b}{\epsilon} \rightarrow \pm \infty[/itex]
[itex]arctan(+\infty) = \frac{\pi}{2}[/itex]
[itex]arctan(-\infty) = -\frac{\pi}{2}[/itex]
So if [itex]a > 0[/itex], you get [itex]arctan(\frac{a}{\epsilon}) \rightarrow +\frac{\pi}{2}[/itex]
If [itex]a > 0[/itex], you get [itex]arctan(\frac{a}{\epsilon}) \rightarrow -\frac{\pi}{2}[/itex]
So if [itex]b > 0[/itex], you get [itex]arctan(\frac{b}{\epsilon}) \rightarrow +\frac{\pi}{2}[/itex]
If [itex]b > 0[/itex], you get [itex]arctan(\frac{b}{\epsilon}) \rightarrow -\frac{\pi}{2}[/itex]
Note also that for any ##\epsilon## you have ##\int_{-\infty}^{+\infty} \delta_{\epsilon}(x)dx =1##.
I know how to prove it now. Thanks for the help.
  • · Replies 26 ·
  • · Replies 25 ·
