Show that there are three collisions and find all find velocities
  • Thread starter Thread starter Destrio
    Collisions
In the discussion, participants analyze a problem involving three spheres with different masses undergoing elastic collisions. When the mass M is less than or equal to mass m, two collisions occur, with the left sphere colliding first with the right sphere of mass m, which then collides with mass M. If mass M is greater than mass m, three collisions happen, as the left sphere hits the first m, which then strikes M and bounces back to collide with the left sphere again. The conservation of momentum and kinetic energy must be applied after each collision to determine the final velocities of the spheres. The discussion emphasizes the necessity of using both conservation laws to solve for the final velocities accurately.
Destrio
There are the 3 spheres in a line, of masses m , m and M. The 2 spheres on the right are slightly separated and initially at rest, the left sphere is incident with speed Vo. Assuming head on elastic collisions:
a) if M =< m , show that there are two collisions and find all the final velocities
b) if M > m, show that there are three collisions and find all find velocities
if M =< m , there will be two collisions because m will hit m which will hit M and all will continue in the +x direction
if M > m, there will be 3 collisions, as m will hit m which will hit M and bounce back hitting the first m again.
mv1i + mv2i = mv1f + mv2f
mVo + 0 = mv1f + mv2f
Vo = v1f + v2f
v1f = Vo - v2f
v2f = Vo - v1f
and then
mv2i + Mv3i = mv2f + Mv3f
m(Vo - v1f) + 0 = mv2f + Mv3f
I'm getting sortof lost here, is there an easier was to work this into 2 equations
Thanks
You have to PROVE these statements, you cannot just assert them.
Conservation of linear momentum on its own is NOT enough to solve this problem. But you are told that the collision are ELASTIC (an elastic collision means kinetic energy is conserved). Aha! you should say.
After each single collision, you have to use conservation of kinetic energy to find the exact solution (there is one, only one). You do this for each solution. You might have to use equations of motions to decide whether there are 2 or 3 collisions.
" You might have to use equations of motions to decide whether there are 2 or 3 collisions."
I'm not sure what you mean by equations of motion
Do I want to use conservation on energy instead of momentum? Or momentum and then kinetic energy?
KEi = KEf
(1/2)mVo^2 + 0= (1/2)mv1^2 + (1/2)mv2^2
Vo= sqrt(v1^2 + v2^2)
or
v1f = Vo - v2f
v2f = Vo - v1f
KEi = KEf
(1/2)mv^2 = (1/2)mv^2
(1/2)mVo^2 = (1/2)m(Vo - v2f)^2 + (1/2)m(Vo - v1f)^2
Vo = sqrt[(Vo - v2f)^2 + (Vo - v1f)^2]
thanks
I'm still stuck on this one, why do I need to use Kinetic energy?
oops, i meant to solve for final velocities
KEi = KEf
(1/2)mVo^2 + 0= (1/2)mv1f^2 + (1/2)mv2f^2
V1f= sqrt(vo^2 - v2^2)
or
v1f = Vo - v2f
v2f = Vo - v1f
KEi = KEf
v2f = sqrt[(Vo)^2 - (Vo - v1f)^2]
thanks
So you're all sorted?
is that how i need to do it:
v1f = Vo - v2f
v2f = Vo - v1f
KEi = KEf
and then again for each following collision?
Vo = v1f + v2f.....(1)
KEi = 1/2m(Vo)^2
KEf = 1/2m(v1f)^2 + 1/2m(v2f)^2
KEi = KEf
1/2m(Vo)^2 = 1/2m(v1f)^2 + 1/2m(v2f)^2
Vo= sqrt[(v1f)^2 + (v2f)^2]
Equate this with (1):
sqrt[(v1f)^2 + (v2f)^2] = v1f + v2f
(v1f)^2 + (v2f)^2 = (v1f)^2 + (v2f)^2 + 2(v1f)(v2f)
So: 2(v1f)(v2f) = 0
So: v1f = 0 or v2f = 0
But how can v2f = 0? This means it collided with the first ball and remained stationary! So obviously:
v1f = 0...(2)
Substitute (2) in (1):
v2f = Vo
So the balls m and m collide once, the first one comes to rest, the second one continues at Vo. This is what we could have guessed as they have the same mass and KE is cnserved.
Do a similar analysis for the second collision.
ok that makes sense
i will be able to complete this problem,
