Show the equality of two expressions
  • Thread starter Thread starter grepecs
    Expressions
grepecs
Show that
\sum_{k=0}^{N-1}e^{\gamma \tau k}\int_{0}^{\tau}F'(k\tau+s)ds
can be written as
\int_{0}^{t}e^{\gamma t'}F'(t')dt'
1. t=N\tau
2. \int_{0}^{\tau}F'(k\tau+s)ds has the same statistical properties for each interval of length \tau, and is statistically independent with respect to k.
I barely know where to start. As a first step, I'm thinking that perhaps "same statistical properties" means that the integral is the same regardless of k, so that
\int_{0}^{\tau}F'(k\tau+s)ds=\int_{0}^{\tau}F'(s)ds,
i.e., k=0. Is this correct?
Without the exponential, the first expression would just be a piecewise definition of the second integral, and a substitution would transform them into each other (can you see how? Hint: which argument values are used in F in the first, second, ... integral?). I guess you need the second relevant equation to get the same result including the exponential, but it could be still interesting to make that substitution.
Thanks. That gives me
\sum_{k=0}^{N-1}e^{\gamma \tau k}\int_{k\tau}^{(k+1)\tau}F'(t')dt'.
What's left now is to move the exponential into the integrand, but I'm not sure how that can be justified.
That I don't know. It does not work for general functions F', but it works if you take the limit N -> infinity (with finite t), and it might work for some special F' even with finite N.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
