Show the following is a metric
  • Thread starter Thread starter chipotleaway
    Metric
chipotleaway
Let (X,d) is a metric space. Show that d_1=log(1+d) is a metric space.
(it's not stated what d is so I'm assumed d=|x-y|)
I've checked positivity and symmetry but am having trouble with showing the triangle inequality holds. i.e. log(1+|x-y|) \leq log(1+|x-z|)+log(1+|y-z|).
It doesn't appear as though log(a+b)≤log(a)+log(b) is always true
You can't assume ##d(x,y)= |x-y|## or even that ##x## and ##y## are real numbers. But that doesn't really matter because ##d## satisfies the triangle inequality just like absolute values would. So if your presumed triangle inequality is written correctly it would be to show$$
d_1(x,y) \le d_1(x,z) + d_1(z,y)$$which means$$
log(1+d(x,y))\le log(1+d(x,z)) + log(1+d(z,y))$$Hint: Try exponentiating both sides.
Likes 1 person
Thanks, this is what I have now:
(1+d(x,z))(1+d(z,y))=1+d(z,y)+d(x,z)+d(x,z)d(z,y)\geq 1+d(x,y)
Then taking logs of both sides
log((1+d(x,z))(1+d(z,y))) \geq log(1+d(x,y))
log(1+d(x,z))+log(1+d(z,y)) \geq log(1+d(x,y))
You have it pretty much figured out. Now how would you write up your final argument that, given that ##d(x,y)## is a metric, that implies ##d_1(x,y)## is? You want your argument in nice logical order, starting with what you are given and ending with what you wanted to prove. Do you see how to do that?
This is what I'm thinking:
Let x,y,z be points in X. Given a metric d on X, we're to show the function d_1=log(1+d) is a metric on X.
<verify first 2 properties>
Consider (1+d(x,z))(1+d(z,y)). We have
<do working to show>
(1+d(x,z))(1+d(z,y)) \geq 1+d(x,y)
Taking the natural logarithm of both sides gives
\therefore d_1(x,z)+d_1(z,y) \geq log(x,y)
Hence, the function d_1 satisfies the triangle inequality.
But that last inequality isn't what you are trying to show. You are trying to show$$
d_1(x,z)\le d_1(x,y)+ d_1(y,z)$$So your final writeup should begin$$
d_1(x,z) = \log(1 + d(x,z))~...\text{string of inequalities here }...\le d_1(x,y)+d_1(y,z)$$
[Edit] Fixed typo missing log
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
