Sign Conventions for Paths and Surfaces for Electromagnetic Calculations
Determining the correct sign of paths and surfaces in electromagnetic calculations is essential for accurate results. For a wire with current density, the normal vector to the cross-section can be either in the +z or -z direction, depending on the chosen orientation. In electrostatics, the sign of the differential path, \textrm{d} \gamma, must also be clearly defined, particularly when both points lie along the same axis. A general rule for orientation follows the right-hand rule, where the thumb points in the direction of the surface normal, and the fingers indicate the boundary path direction. Understanding these conventions is crucial for applying Maxwell's Equations correctly.
Jessehk
Hello all.
I'm trying to figure out how to determine the correct sign of paths and surfaces defined for calculating quantities in electromagnetic problems.
For example, say there's a wire in the shape of a rectangular prism along the z-axis with some current density, \vec{J}.
Then the current through the wire is I = \int_S { \vec{J} \cdot \textrm{d} S }. Now, \textrm{d} S = \textrm{d} x \textrm{d} y \hat{z} but how can we know the sign of the normal to the cross-section? Is it in the -z direction (ie, -\hat{z}) or the +z direction?
Similarly, the potential difference in an electrostatic field is V_{12} = - \int_2^1 \vec{E} \cdot \textrm{d} \gamma but how do we define the sign of \textrm{d} \gamma? For example, if both points are in the same axis, is the direction of the path from (1) to (2) or from (2) to (1)?
Is there a general rule? I apologize if this question is not clear, and thanks in advance. :)
There are only sign problems if you consider the integral form of Maxwell's Equations. Take, e.g., Faraday's Law, which reads in differential form
\vec{\nabla} \times \vec{E}=-\partial_t \vec{B}.
If you integrate this equation over a fixed (i.e., time independent) surface F with boundary \partial F. You can choose the orientation of the surface as you like or as is most convenient for you, but then you like to apply Stokes integral theorem, and then you have to orient the boundary in the same way as the surface. By convention, this is defined according to the right-hand rule: Point the thumb of your right hand in direction of the chosen surface normal (defining the orientation of the surface). Then the orientation of the boundary path in Stokes theorem is given by the direction of the fingers. With this convention, the integral form (for time-independent surfaces and boundaries) reads
\int_{\partial F} \mathrm{d} \vec{x} \cdot \vec{E}=-\frac{\mathrm{d}}{\mathrm{d} t} \int_F \mathrm{d}^2 \vec{F} \cdot \vec{B}.
BTW: For moving surfaces we recently had a big discussion in this forum.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
