How do I correctly graph FFT results in signal processing?
The discussion focuses on graphing FFT results in signal processing using Excel. The user is new to the subject and is struggling to visualize the FFT data correctly, specifically needing to remove DC zero values. Key points include the need to calculate frequency bins using the sampling rate and the number of FFT points, which can be expressed as f=(0:Nfft-1)*Fs/Nfft. Suggestions include plotting amplitude versus frequency and using logarithmic axes for better visualization. Properly handling the data and understanding the relationship between time and frequency is essential for accurate graphing.
phenommsu1
Hello all. I am working on a problem for class that is taking some time data and changing it to frequency data. I am using excel and the fast Fourier transform(fft).
I am having a problem graphing the results. I am very new to signal processing.
I am only given the data which is 1024 points long.
I will only ask for help with one because if I figure this one out I can do the rest.
The period is .117. Making the sampline rate 1/.117.
I have the two columns of data here is an example.
The first column is (1*(1/.117)/1024) and the second is the fft values.
pres43 abs imag
0.006643282 162509.4667
0.013286565 388.025981
0.019929847 600.4277992
0.026573129 499.1078937
0.033216412 447.4588355
0.039859694 102.7576392
0.046502976 276.7567742
0.053146259 358.0531147
0.059789541 289.5977569
0.066432823 129.8177899
0.073076105 91.85556182
0.079719388 250.3116294
0.08636267 35.77585877
0.093005952 218.271273
0.099649235 216.1229107
0.106292517 215.5078932
0.112935799 110.6895935
0.119579082 153.2837982
0.126222364 194.9400366
0.132865646 96.83955867
My problems is that I don't know how to graph the values correctly. The graph as it stands is not right. Someone told me that I have to remove the DC zero values? I do not know how to do that and that is why I am asking for help.
Thank you
May be useful
This may be helpful, it may be completely wrong... you presumably understand it better than I do!
I've never been taught Fourier transforms, but I've read about them and used them occasionally - I can't quite make sense of you're data, but here's my basic understanding of FFT & graphing it.
Data in
y = x(t) {REAL amplitude as function of time}
Data out
p = A * g(Bf) {COMPLEX "phasors" as function of frequency; A & B are constants}
|p| = amplitude of wave with frequency f
arg p = phase offset of wave with frequency f
Presumably, you want to produce a graph of amplitude vs. frequency - so by working out the constants A & B, you can produce a table of amplitudes (and if needed, phase offsets) for corresponding frequencies. Once this is done, a simple scatter or line graph will give you what you want (possibly using logarithmic axes).
Also, if your sample rate is too low, or a strong wave with period larger than the data length exists, then you may get a large rise in amplitude towards the lower frequencies.
if you have N samples in time with Ts(Time sampling or samping rate) so you can write the time like
t=(0:N-1)*Ts;
in the frequency demain, you have Fs=1/Ts, and you have Nfft=1024, so the frequency can be written like
Now you can plot your data in time & frequency:
plot(t,data);// in time
plot(f,fft(data,Nfft)); // in frequency.
good luck.
t=(0:N-1)*Ts;
good luck.
this is in matlab?
TheAnalogKid83 said:
this is in matlab?
Yes if you want but if you are not familiar with MATLAB just use
f=(0:Nfft-1)*Fs/Nfft to get the spectum bins at right frequencies.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
