Signal Processing mathematics books ?(laplace, fourier )
Recommendations for math books on Fourier and Laplace transforms, convolution, and transfer functions include Schaum's guides, particularly the one focused on signal processing. "The Elements of Statistical Learning" is noted for its effective discussion on convolution's impact on data. The topic is often referred to as "Linear System Theory" in older terminology, which typically appears in differential equations courses. Users suggest that Schaum's DSP book is particularly useful for understanding these concepts. Overall, these resources are considered valuable for grasping the mathematical foundations of signal processing.
shuby
Hello,
Can you suggest me some good Math books about Fourier laplace transforms, convolution, transfert functions and stuff ?
Because all I have right now is some crapy math notes and an electricity book that doesn't mention anything about math theory.
I tried google but I really don't know what kind of math is that.
Thanks !
if you're getting a Schaum outline, and you want signal processing, then i think it is better to get the outline about signal processing: https://www.amazon.com/dp/0070306419/?tag=pfamazon01-20 .
in the olden days we called this "Linear System Theory".
I graduated all of last year and the courses I took were called Linear Systems I and II. I think mathematicians call it something else, but it usually first shows up in differential equations.
The textbook for one of my courses was the Schuam's DSP book, so I can also rec that one. I've also got the Schaum's Fourier book, but haven't found it to be that useful.
Thank you that's very helpful !
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
