Signal Transmission from Mars to Earth
The discussion centers on the types of radio signals used for communication between Mars and Earth, specifically noting that NASA employs microwave C band and X band frequencies for this purpose. The uplink frequency is approximately 7.8 GHz, while the downlink is around 8.4 GHz, allowing for efficient transmission of data over vast distances. Microwaves are preferred due to their superior travel capabilities in space, lower power requirements, and higher data capacity compared to lower frequency bands. The modulation method likely used by NASA is Quadrature Amplitude Modulation (QAM), which facilitates dense data transmission. Additionally, there is interest in building personal receivers to capture signals from Mars probes.
NeoScience
When they say it takes about 5-6 mins to send radio signal back to earth, what kind radio signal are they talking about? Not FM/AM signal right?
Astronomy news on Phys.org
I'm betting digital FM
Looks like the frequency is in the UHF range (the same frequency band as some tv stations and many other types of radio communications), and yes, I'd also guess that they are digital, frequency modulated.
Also, at its minimum, Mars is about 35 million miles (3 minutes) and at its maximum, it is about 220 million miles (19 minutes).
NASA uses microwave C band and X band frequencies to communicate with the probes. Uplink is in C band about in 7.8 GHz range, and downlink is 8.4 GHz.
Microwaves travel a lot better in space, require less power, and more data can be sent than on lower frequency bands.
I don't remember what modulation Nasa uses, but it's probably QAM because you can cram a lot of data.
If interested, you can build your own receiver to pick up signal from Mars probes, no kidding.
http://www.uhf-satcom.com/vex/
hope that helps
hope that helps
Wow cool contraptions. Thanks. I'm try to set one up.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
