lazyaditya
- 176
- 7
We say that a slope can be calculated as the ratio of the perpendicular to the base , Then what does differentiation of the equation shows "dy/dx"?
Differential calculus involves the evaluation of that Δy / Δx but taken to its extreme.We say that a slope can be calculated as the ratio of the perpendicular to the base of a line tangential, Then what does differentiation of the equation shows "dy/dx"?
lazyaditya said:Ya that's what i m saying suppose y =3x^2 then on differentiation i would get (dy/dx=6x) then at point x=3 the slope would be 18. Then isn't slope also calculated as (y2-y1)/(x2-x1) then at point x = 3 isn't it should be 9 ?
Yes. So if you take two points (x1,y1) and (x2,y2) on that curve, where x1 and x2 are very close to 3, then that quotient will be very close to 18.lazyaditya said:Then isn't slope also calculated as (y2-y1)/(x2-x1)
lazyaditya said:Then what is the significance of one over the other ? I mean in which situation which one should i prefer ?
Differentiation gives the exact value of the slope at any point you choose. Using the "pair of points" method gives an approximation, you are in effect approximating the curve with a straight line.lazyaditya said:Then what is the significance of one over the other ? I mean in which situation which one should i prefer ?
NascentOxygen said:Differentiation gives the exact value of the slope at any point you choose. Using the "pair of points" method gives an approximation, you are in effect approximating the curve with a straight line.
A "silly math question" is a question that may seem nonsensical or illogical, but often has a mathematical concept or solution hidden within it.
Silly math questions can help improve critical thinking and problem-solving skills. They also make math more enjoyable and can challenge our understanding of mathematical concepts.
One example of a silly math question is: "If a chicken and a half lays an egg and a half in a day and a half, how many eggs will seven chickens lay in seven days?" The answer is 49 eggs, as each chicken lays one egg per day and there are seven chickens. While this question may seem silly, it requires logical thinking and basic math skills to solve.
No, silly math questions can be enjoyed by people of all ages. They can be used as a fun way to practice and strengthen math skills for both children and adults.
Silly math questions can be created by taking a traditional math problem and adding a humorous or unexpected twist to it. They can also be inspired by everyday situations or objects and finding a way to apply mathematical concepts to them.
