Similarity between velocity and momentum
  • Thread starter Thread starter kaushikquanta
    Momentum Velocity
Momentum, defined as the product of mass and velocity, is a vector quantity, while mass is a scalar. Both momentum and velocity share similarities, such as being collinear vectors that have the same unit vector. The magnitude of momentum increases when mass is greater than one, but this is dependent on the choice of units, making comparisons arbitrary. Additionally, force represents the change in momentum when mass is constant, linking acceleration and momentum through their definitions. Overall, the discussion highlights the complexities and arbitrary nature of comparing magnitudes of momentum and velocity.
kaushikquanta
as momentum is product of mass and velocity ,it is a vector quantity but mass is a scalar.when a scalar is multiplied to a vector ,it's magnitude increases .then there must certain similarities between velocity and momentum.
The similarity is that the vectors are collinear, i.e. they share the same unit vector. Also, the magnitude only increases if the scalar (mass) is greater than 1.
Also, since acceleration is the change in velocity, force is the change in momentum if you assume mass to be constant.
##A = \frac{d}{dt}V##
##F=mA = m\frac{d}{dt}V=\frac{d}{dt}(mV) ##
Since mass is not a unitless quantity, whether it is greater or less than one depends on one's choice of units. It is arbitrary. Since momentum and velocity are not unitless quantities, whether one has larger magnitude than the other also depends on one's choice of units. It is also arbitrary.
The comparison of magnitudes seems pointless. It is like asking whether an apple is rounder than an orange is tall.
Likes davenn and sophiecentaur
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
