Simple Battery Misunderstanding
Applying a small voltage, such as 1V, to the negative terminal of a 1.5V alkaline battery will not create a current unless the other terminal is also involved in the circuit. The concept of voltage, or potential difference, is crucial to understanding this interaction. If the battery is isolated and not connected to any load, the applied voltage will not affect the battery's performance. However, if a connection is made, a flow of electrons may occur, depending on the capacitance of the setup. Overall, without a complete circuit, the battery remains unaffected by the external voltage.
Mzzed
If a small voltage - say 1V, is applied to the negative terminal of a 1.5V alkaline battery (although I don't think the type of battery matters?) will this create a current between the 1V and the negative terminal until the charges are somehow balanced? If not, what will this situation do to the battery?I know you are able to connect batteries in series to achieve a larger voltage than a single battery, but I'm not exactly sure what occurs inside the batteries to make this occur.
I've learned quite a bit about electronics during my degree but the details of batteries haven't been explained at all and this problem above has always confused me.
Thanks!
Likes Mzzed and jim mcnamara
Then you are accustomed to "ideal voltage source" and "ideal current source".
Until you've familiarized yourself with the chemistry inside a battery, just think of it as an ideal voltage source and some resistance in series, with a battery label wrapped around it.
The phrasing of your question implies that you don't quite grasp the concept of "voltage" aka "potential difference".
We get lots of questions on that subject. Here's the most recent: https://www.physicsforums.com/threads/physical-basis-of-voltage.917327/
See also this not too terribly old one
https://www.physicsforums.com/threads/what-does-more-less-voltage-mean.852532/#post-5347090
Likes Mzzed
Firstly, Voltage must be applied across two points. Nothing can 'happen' to the battery unless the other terminal is involved in some way - otherwise the mean potential of the two terminals will change but nothing else. But how much, will depend what is actually connected to the other terminal of your 'voltage source'.
Objects cannot affect their Electrical Potential by pulling themselves up by their own bootstraps. Try a diagram of what you are asking about. You stand to get a better answer. :smile:
I'm not disagreeing with or contradicting other replies but possibly yes depending on how you model the set up...
Consider this...
1) The 1.5V battery starts off with it's negative terminal in contact with a metal plate. We will call this plate "Earth".
2) The battery is then raised up on insulators so that there is a gap between the negative terminal of the battery and the Earth plate.
3) This gap will form a crude capacitor.
4) The 1V source is inserted between the Earth plate and the battery negative terminal (eg in parallel with the capacitance detailed in 3)
5) Applying a voltage to the capacitor causes it to become charged to that voltage.
6) Charging a capacitor requires a flow of electrons.
We can estimate the charge that will flow for something like an AA battery or coin cell in the above model..
The equation for the charge on a capacitor is Q = CV
So the amount of charge that flows depends on the capacitance. For something like a small button cell or AA the capacitance will be small. The general equation for a flat plate capacitor is..
C = kε0A/d
For air kε0 is about 1.26 x 10-6 H/m (Error see follow up posts below)
Lets say the diameter of the cell is 0.01m (=1cm) and d the air gap is the same.
Then the capacitance would be around...
C = 1.26 * 10-6 * Pi * 0.0052/0.01
= 9.9 * 10-9
call it 10nF (Aside: that's a bit larger than I expected but I can't see if/where I made a mistake)
To charge the stray capacitor to 1V the charge required would be
Q = C*V = 10*10-9 Coulombs
I think we can even calculate how many electrons will flow?...
The charge on an electron is about 1.6 × 10-19 Coulombs so..
No = 10*10-9 / 1.6 × 10-19
= 62 * 109 electrons.
Your mileage may vary.
Darn it. Google gave me permeability rather than permittivity!
That 1.26 x 10-6 H/m should be 8.9 x 10-12 C2.N-1.m-2
I knew the units look odd.
So the capacitance should be
C = 8.9 * 10-12 * Pi * 0.0052/0.01
= 7 * 10-14
= 0.07 * 10-12
= 0.07pF
Much closer to what I expected.
That makes the charge 7 * 10-14 Coulombs
and the number of electrons
= 7 * 10-14 / 1.6 × 10-19
= 437,500
Likes Mzzed
Ah thanks, I am still to read the links but I'm guessing an applied voltage like this shouldn't affect the battery in any way then. Thankyou!
If the battery isn't connected to anything that's correct.
Likes Mzzed
