How to Solve a Mid-Problem Calculus Step?
  • Thread starter ElDavidas
  • Tags
    Calculus
In summary, the conversation discusses clarifying a step in a problem involving finding the derivative of a function of x. It is recommended to use the quotient rule and to apply the chain rule when differentiating the square root expression. The notation for the derivative of y is also discussed.
ElDavidas
80
Hi,
could someone please clarrify how to do this step? It's midway through a large problem and I'm not so sure about it.
y is a function of x.
[tex]\frac {d}{dx} ( \frac {y} \sqrt{1 + y'}} )[/tex]
Please excuse the Latex. The square root of 1 + y' is being taken on the denominator .
Do you just use the quotient rule? and does [itex] \frac {d} {dx}y[/itex] equal [itex]y'[/itex]?
thanks
I can't see the LaTeX but dy/dx does equal y'.
dy/dx is Leibniz's notation and using the prime mark is Lagrange's notation.
f(x)=y, so f'(x)=y' and if y is a function of x then the dy/dx means the derivative of y with respect to x.
Yes, use the quotient rule. To differentiate the square root expression you could use the chain rule. It may help to look at the denominator as [tex](1+y')^\frac{1}{2}[/tex].
Further, since that is a function of y and you are differentiating with respect to x, you will have to multiply each derivative by y'.
1. What is calculus?
Calculus is a branch of mathematics that deals with the study of continuous change. It is used to analyze and model various real-world phenomena such as motion, growth, and decay.
2. What is the difference between differential and integral calculus?
Differential calculus focuses on the rates at which quantities change, while integral calculus deals with the accumulation of quantities over a period of time. In other words, differential calculus helps us understand how fast things change, while integral calculus helps us understand the total change.
3. What are the two main branches of calculus?
The two main branches of calculus are differential calculus and integral calculus. Differential calculus deals with rates of change and slopes of curves, while integral calculus deals with the area under curves.
4. What is the fundamental theorem of calculus?
The fundamental theorem of calculus states that the integral of a function can be calculated by finding the antiderivative of that function and evaluating it at the upper and lower limits of integration.
5. Why is calculus important?
Calculus is important because it provides us with tools and techniques to solve real-world problems involving continuous change. It is used in many fields such as physics, engineering, economics, and statistics.
