Fix Circuit Board: No Expertise Needed
  • Thread starter Thread starter 120rob
    Board Circuit
The discussion focuses on repairing hair clippers that have a blown resistor after possibly getting wet. The clippers operate at 120v AC and emitted a toxic smell when they failed. Participants emphasize that the blown resistor might not be the root cause of the issue, as it could have failed to protect other components. They discuss the importance of identifying the resistor's full color code for proper replacement and suggest checking local stores for compatible parts. Overall, the conversation provides guidance on troubleshooting and repairing the clippers without needing extensive expertise.
120rob
(incase you are wondering I am not educated but have small mechanical know how) but I don't fully know how circuits behave. I have these hair clippers that seemed to blow a resister. It is a grey tube with a green stipe on one end and a gold stripe on the other. It is difinitely fried. I must get my hair clippers working again (without the purchase of a whole new kit). So do you think you can help me!
Hi 120Rob
Please tell us more:
what voltage are the clippers run at?
did a nasty smell come from the clippers, hot and rich and toxic-smelling?
Please tell us how the clippers died, and perhaps we can tell you what may have gone wrong.
Good luck
On the back of the razor it says,
120v AC 60Hz 5W
And yes, rich toxic smell came from razor when it quit working. I think I might have gotten it wet on the inside of the clippers.
Couple of things: First, the blown resistor may or may not be the root cause problem. It's possible that it sacrificed itself to protect whatever the true problem source was. So, you may replace this and maybe not fix the problem.
There should be more stripes on the resistor. These may be not identifiable due to scorch marks. The first green means "2". the last gold bar means "+/- 10%" and is the tolerance for the accuracy of the resistor value. You need two more bars from the first green end which are the next value for resistor (e.g. another green would, with the first then mean 22) and the next bar is 'power of ten' (which makes it a 2.2 ohm, or 22, or 2.2Kohm, etc. resistor). You can find the color code list with a simple web search.
Then there is the power handling level of the resistor (e.g. 1/4 watt, 1/2 watt, etc.). Look in Radio Shack (what few parts remain) for something of similar physical size and read off the wattage level for guidance.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
