I think you may mean that a current is set up and circulates for ever in the absence of any resistance.
That thought entered my mind and i considered saying it, but that necessitates either ideal or superconducting wire
This is 'ideal' and you must continue with an ideal model. Disconnecting (breaking) the circuit must be instantaneous and complete. Ldi/dt will be infinite so the volts developed will be infinite.
That's the scenario i had in mind.
This is not a real scenario.
quite agreed.
ffp needs to grasp the concept of an ideal inductor's behavior then tone his thought experiment down to realty;; at least that's how i learn basics.
The nearest to it is an inductor with finite resistance somewhere in the circuit (and a top-up current from a supply) and a switch that takes a finite time to break the circuit. As the current falls to zero, there will be a (possibly large) emf induced. This is an everyday situation and can be dealt with - as mentioned previously.
You and i have both 've had our fingers on automobile points i know, so our understanding of inductance is firmly ingrained to the point it's intuitive now. We can barely remember when it wasn't.
ffp is struggling up his learning curve and sadly probably will not ever encounter a battery and coil or magneto ignition , which places the concept so viscerally at your fingertips
so I was searching for a terse phrase that conveys the concept.
if an ideal inductor is interrupted by an ideal switch
the energy must go into the capacitance across the contacts of that switch
and the voltage on that capacitance will rise until it's absorbed all the energy
hence my phrase "to whatever is necessary.."
hence also my phrase "whatever is between those [STRIKE]contacts[/STRIKE] terminals" - even if it's just free space (which has capacitance)
Ahhh i see you've already posted whilst i was typing
and you expressed my points more succinctly
sorry if i butted-in, just wanted to nudge the discussion a little .
regards as always - old jim
