Simple differential equation - Finding the solution
dumbdumNotSmart
We are given the following differential equation:
$$ y+yy'-xy'=0 $$
Let's find the solution.
So in my course usually we have to do some sort of substitution by the lines of x/y=z or y/x=z. This equation has proven difficult. I have taken a look at wolfram alpha and the y(x)=xv(x) substitution is not one I am familiar with.
##y + (y - x ) y' = 0##
Can be written as:
##y' = -\frac{y}{y-x} = -\frac{1}{1 - x/y} ##
So, if you were to use ## z = x/y,## you would get ##z' = \frac{yx' - xy'}{y^2}##.
Then substituting into the original equation would give yy' + y^2 z' = 0.
Assume y is not zero, and you get:
##\frac{y'}{y} = -z' ##
Integrate both sides.
Could you give me a more chew down process of the substitution? What goes where to get that lovely equation down there at the bottom of your answer?
I think he did show how he got it.
Work through a bit of algebra.
Here is a bit more information to guide your algebra.
##z' = \frac{yx' - xy'}{y^2} = \frac{1}{y^2}( y - xy') ##. So ##y^2 z' = y - xy'## which matches 2 of the 3 terms in your original equation.
So, substituting into the original equation would give ##yy' + y^2 z' = 0##.
Assume y is not zero, and divide the whole thing by ##y^2##, you get:
##\frac{y'}{y} + z'=0 ## which is the same as ##\frac{y'}{y} = -z' ##.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
