Simple Dynamics Problem Requiring Explanation
The discussion revolves around a dynamics problem involving two boxes sliding down a slope with uniform acceleration. The key points include the need to clarify the timing of each box's movement, particularly how Box A has been moving for a time "trelease" before Box B is released. There is confusion regarding the application of motion equations, specifically why certain time intervals are not used in calculations. The participant emphasizes that the distance between the boxes after one second should account for their respective travel times, leading to a clearer understanding of the problem. Overall, the conversation highlights the importance of correctly applying kinematic equations in relation to the timing of events.
kspabo
Boxes are placed on a slope at uniform intervals of time trelease and slide down the slope with uniform acceleration. Knowing that as a box B is released, the preceding box A has slid 6 meters down the slope and that 1 second later they are 10 meters apart, determine the following:
(a) The value of trelease
(b) The acceleration of the boxes.
ΔV = a⋅Δt
Δx=Vi⋅t+½⋅a⋅t2
2⋅a⋅Δx=Vf2-Vi2
This problem isn't actually homework, I'm just studying. I'm posting the solution to the problem because I simply don't understand how exactly they arrive at the equations that they do. Here it is:
http://i.imgur.com/oSyIFsm.png
For example, equation (2) doesn't make sense to me as t = tr + 1, yet in the problem t = 1. Also, how come in eqn. (3) they don't employ the 10 m @ t=tr+1? Why is Δx simply xA@tr+1?
When using the equations of motion listed you need to put the time interval that the particle has been under that constant acceleration.
When Box B is released: Box A has already been traveling for "tr" time. Box B has traveled for "Zero" time.
After 1 second of releasing Box B: Box A has traveled for "tr time PLUS One extra second". Box B has only traveled for "1 second".
Coming to Eq. 3:
Notice that the diagram isn't drawn properly. After 1 second both the boxes would have traveled a certain distance from their initial position. The distance between them is given to be 10m. So you need to use (xb - xa) = 10 @t=tr+1.
That really clears it up. Thank you, I appreciate that.
