Simple electrical engine theory
The discussion focuses on a project involving the construction of a simple battery and electrical engine, specifically a 12V lead-acid battery and a basic engine design using matchboxes and wires. The creator is struggling to find accessible theoretical information about the engine's operation, as existing resources are too advanced for their current understanding. They seek guidance on electricity and magnetism, noting the absence of magnets in their design despite the rod being positioned within one. Participants are encouraged to share helpful resources or tips to improve their knowledge in these areas. The thread highlights the importance of foundational understanding in electrical engineering for successful project completion.
klette
I'm working on a project that has the goal to build a battery and an electrical engine.
The battery, with theory, is all done ( a simple 12V acid/lead based on 3mol H2SO4 ).
The engine it self has also been built, a fairly simple construction; two matchboxes on a rod with wires around. ( poorly displayed in the attachment ).
But the problem is that I'm having a hard time finding the theory behind the engine. The info I find around it far too advanced accordingly to my current grade.
If anyone have tips about what to look for, some urls or similar, Please give me a hand :)
What do you know about electricity and magnetism? Also, shouldn't there be magnets in that picture?
the rod is "inside" a magnet ( forgot to mention that )
I know some electricity, but my magnetism knowlegde is poor, but I can lean ;)
nice.
Thanks
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
