Simple energy question with rotation
  • Thread starter Thread starter oreosama
    Energy Rotation
To determine the minimum height h for a solid sphere rolling down a hill and remaining on track through a loop, the energy conservation equation is applied. The equation mgh = mg2R + 1/2 Iω^2 leads to the conclusion that h must equal 11/5 R. At the top of the loop, the normal force is zero, and the centripetal force equation m*v^2/R = mg indicates that v^2 = gR. It is emphasized that the height must account for both translational and rotational kinetic energy, suggesting that the initial height must be higher than that required for a block sliding without friction. The discussion confirms the calculations and stresses the importance of considering all forms of kinetic energy at the loop's peak.
oreosama
a small solid sphere of mass m and radius r starts from rest and rolls down a hill without slipping. the sphere encounters a loop of radius R where R >> r.
Given R determine the min height h such that the ball remains on the track throughout the loop
I = 2/5 mR^2
ω = v/r
highest point requiring most energy is at top of loop:
mgh = mg2R + 1/2 * 2/5 m r^2 *v^2/r^2
gh = 2Rg + 1/5*v^2
at top of loop, normal force is 0,
Fy = N + mg
ma = mg
m*v^2/R = mg
v^2 = gR
gh = 2Rg + 1/5 Rg
h = 11/5 R
this is correct?
To check your results - it is useful to compare to something:
i.e. If this were a block sliding around the track without friction, then what would the minimum h have to be?
(for the ball, some energy is stored in rotation - so you need to start higher than this.)
How fast is the ball rolling at the top of the hoop?
(i.e. is the kinetic energy a lot or a little more than the potential energy there? says if you should start a little higher or a lot higher.)
Have you included all of the kinetic energy at the top?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
