I'msorry
- 4
Hello everyone!
A weightless, friction-less pulley and rope system connect two blocks, called A and B. A has a mass of 2.2 kg, and B has a mass 4.0 kg. Both blocks are on a scalene triangle, with the pulley located at the triangle's apex. Block A is on an incline of 51 degrees, and block b is on an incline 21 degrees. The coefficient of kinetic friction between each block and the surface is 0.30.
Here is the visual of the problem: http://i.imgur.com/k8YSshe.jpg
Now, so far, so good. Here is where things get tricky:
If mA moves up, and mB moves down, determine their acceleration.
Force (friction) = coefficient of friction * Normal force
ƩF = ma
I assigned the conventional "tilted" x-y axis, with the x-axis being parallel to the incline under block B.
X-direction for block B:
mass*g*sin21' - co of fr*cos21'*mass*g =
14.048 - 10.979 = 3.069
X-direction for block A: (all negative because going against movement, as defined in the problem)(also equal to tension)
-(mass*g*sin51') - co of fr*cos51'*mass*g =
-16.755 -4.07 = -20.825
Which can't possibly be correct. To be honest, I've never done a problem with two different inclines like this before, but the numbers just seem off to me. I have absolutely no idea what to do from here, which means I'm probably grievously wrong somehow.
This problem has made me so confused. Thank you for even considering helping me!
ƩF = ma
