Simple Gauss-Jordan Elimination
  • Thread starter Thread starter Saladsamurai
    Elimination
Saladsamurai
I have done the following problem over and over and keep getting the same result. So either the book answer is wrong or I am making the same mistake over again:
\left[\begin{array} {cccc}<br /> 5&amp;-2&amp;6&amp;0\\<br /> -2&amp;1&amp;3&amp;1\\<br /> \end{array}\right]
\left[\begin{array} {cccc}<br /> 1&amp;-\frac25&amp;\frac65&amp;0\\<br /> -2&amp;1&amp;3&amp;1\\<br /> \end{array}\right]
\left[\begin{array} {cccc}<br /> 1&amp;-\frac25&amp;\frac65&amp;0\\<br /> 0&amp;\frac15&amp;\frac{17}{5}&amp;1\\<br /> \end{array}\right]
\left[\begin{array} {cccc}<br /> 1&amp;0&amp;8&amp;2\\<br /> 0&amp;1&amp;17&amp;5\\<br /> \end{array}\right]
Am I screwing this up somewhere?
I ended up with different numbers in the 3rd column.
\left[\begin{array} {cccc}<br /> 1&amp;0&amp;12&amp;2\\<br /> 0&amp;1&amp;27&amp;5\\<br /> \end{array}\right]
In my first step, I added 2 times row 1 to -5 times row 2. Then I added 2 times row 2 to row 1. Finally, I replaced row 1 with 1/5 of itself. It is usually simpler to keep integer values for as long as possible.
@Saladsamurai, [STRIKE]When you go to eliminate the -2, you want to add row 1 to row 2. You're subtracting it.[/STRIKE]
3 + 12/5 = 15/5 + 12/5 = 27/5
Yeah! I just caught that :/ Man.. I must have added 6/5+3=17/5
like ten times! Stupid brain gets sucked into following
a pattern
thanks! :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
