Simple Harmonic Motion in x direction
10 replies · 3K views · last reply
Yubsicle
A simple harmonic oscillator, with oscillations in the x direction, has velocity given by: $$v_{x} = (2.2 \frac {\mathrm{m}} {\mathrm{s}}) \sin [(6.9 \frac {\mathrm{rad}} {\mathrm{s}}) t]$$.
Find the values of ##\omega , A, f , T ,## and ##\phi##
$$v_{x} = \frac {dx}{dt}$$
$$x = A \cos (\omega t - \frac{\pi}{2}) = A \sin \omega t$$
$$\omega = \frac{2\pi}{T} = 2 \pi f$$
I integrated v with respect to t and got $$x = (-0.3188\mathrm{m})\cos [(6.9\frac{rad}{s} t)] $$
(I'm assuming that the integration constant C = 0, please correct me if I'm wrong). The first problem I have is that A is negative, and my understanding is that amplitude can only be positive. Do I take the absolute value of -0.3188 and get ##A = 0.3188##, did I make a mistake, or do I need to do more steps?
The second problem is that the formula is ##x = A \cos (\omega t - \frac{\pi}{2})## but i don't have a ##-\frac{\pi}{2}## anywhere. Again, is there an easy fix, did I mess up, or have I not completed all the steps needed? Thanks in advance.
Oh, it looks like I misread my textbook. Apparently ##x = A \cos(\omega t - \frac{\pi}{2})## only works if ##x = 0## when ##t = 0##, and otherwise it's ##x = A \cos(\omega t + \phi)##. So I was wrong in assuming that C = 0.
That brings me to $$(-0.3188 \mathrm{m})\cos [(6.9\frac{\mathrm{rad}}{\mathrm{s}})t]+C$$ , which is missing ##\phi## and I really don't know what to do about C. Where do I go from here?
Not really. The integration constant is related to the average displacement. This can be chosen to be zero. The general statement for ##x## with this choice is what you gave, ##x = A \cos(\omega t + \phi)##. Try applying some trigonometric identities to this.
I think I get it now. Plugging ##t = 0## into the equation given by the problem gives ##v = 0##, so ##\sin(\omega t+ \phi) = 0## if ##\phi = 0## and so ##x = A \cos\omega t## . However, I still get ##A = -0.3188##. Do I just take the absolute value, since the cosine function has the same "height" on both sides of the y-axis (not sure how to word it)?
Not relevant to the problem, but OK.
Right.
You could but you can also wind up with an expression with A>0. Consider -cos(x) = sin(x + φ) & you pick the correct φ.
? I don't think that is a correct solution for x(t) regardless of the constant of integration or the sign of A.
I suggest you do what I proposed and apply trigonometric identities to the general expression.
Yubsicle said:
I still get A=−0.3188A. Do I just take the absolute value
No, just taking the absolute value, and keeping all else the same, yields a different equation, so will not match the data. The equation with a negative amplitude is a valid description of x, but doesn't fit the canonical form. I.e., by convention, we generally arrange that the amplitude is positive by adjusting the phase.
Alright, I used the trig identity ##\cos(\theta + \pi) = -\cos(\theta)## and got ##\phi = \pi \:\mathrm{rad}## and ##A = 0.32\:\mathrm{m}## (rounded to 2 sig figs), as well as ##\omega = 6.9\:\mathrm{rad/s} , T = 0.91\:\mathrm{s}, f = 1.1\:\mathrm{Hz}##. Is my use of trig identities, and the value for ##\phi## correct?
Does it matter that I used ##\cos(\theta + \pi) = -\cos(\theta)## instead of the one you suggested?
Yubsicle said:
Is my use of trig identities, and the value for ϕ correct?
Yes.
No, that's fine.
