Simple Harmonic Motion in x direction
The discussion revolves around solving for parameters of a simple harmonic oscillator given its velocity function. The user initially integrated the velocity to find the position function but encountered issues with the amplitude being negative and the phase shift. Clarifications were provided that the amplitude should be positive, and the negative sign can be addressed by adjusting the phase shift. The user successfully applied trigonometric identities to derive the correct values for amplitude, angular frequency, period, frequency, and phase shift. The final consensus confirms that the approach and results, including the use of the identity for cosine, are correct.
Yubsicle
A simple harmonic oscillator, with oscillations in the x direction, has velocity given by: $$v_{x} = (2.2 \frac {\mathrm{m}} {\mathrm{s}}) \sin [(6.9 \frac {\mathrm{rad}} {\mathrm{s}}) t]$$.
Find the values of ##\omega , A, f , T ,## and ##\phi##
$$v_{x} = \frac {dx}{dt}$$
$$x = A \cos (\omega t - \frac{\pi}{2}) = A \sin \omega t$$
$$\omega = \frac{2\pi}{T} = 2 \pi f$$
I integrated v with respect to t and got $$x = (-0.3188\mathrm{m})\cos [(6.9\frac{rad}{s} t)] $$
(I'm assuming that the integration constant C = 0, please correct me if I'm wrong). The first problem I have is that A is negative, and my understanding is that amplitude can only be positive. Do I take the absolute value of -0.3188 and get ##A = 0.3188##, did I make a mistake, or do I need to do more steps?
The second problem is that the formula is ##x = A \cos (\omega t - \frac{\pi}{2})## but i don't have a ##-\frac{\pi}{2}## anywhere. Again, is there an easy fix, did I mess up, or have I not completed all the steps needed? Thanks in advance.
What happened to your general phase shift ##\phi##?
Oh, it looks like I misread my textbook. Apparently ##x = A \cos(\omega t - \frac{\pi}{2})## only works if ##x = 0## when ##t = 0##, and otherwise it's ##x = A \cos(\omega t + \phi)##. So I was wrong in assuming that C = 0.
That brings me to $$(-0.3188 \mathrm{m})\cos [(6.9\frac{\mathrm{rad}}{\mathrm{s}})t]+C$$ , which is missing ##\phi## and I really don't know what to do about C. Where do I go from here?
Not really. The integration constant is related to the average displacement. This can be chosen to be zero. The general statement for ##x## with this choice is what you gave, ##x = A \cos(\omega t + \phi)##. Try applying some trigonometric identities to this.
I think I get it now. Plugging ##t = 0## into the equation given by the problem gives ##v = 0##, so ##\sin(\omega t+ \phi) = 0## if ##\phi = 0## and so ##x = A \cos\omega t## . However, I still get ##A = -0.3188##. Do I just take the absolute value, since the cosine function has the same "height" on both sides of the y-axis (not sure how to word it)?
Not relevant to the problem, but OK.
Right.
You could but you can also wind up with an expression with A>0. Consider -cos(x) = sin(x + φ) & you pick the correct φ.
? I don't think that is a correct solution for x(t) regardless of the constant of integration or the sign of A.
I suggest you do what I proposed and apply trigonometric identities to the general expression.
Yubsicle said:
I still get A=−0.3188A. Do I just take the absolute value
No, just taking the absolute value, and keeping all else the same, yields a different equation, so will not match the data. The equation with a negative amplitude is a valid description of x, but doesn't fit the canonical form. I.e., by convention, we generally arrange that the amplitude is positive by adjusting the phase.
Alright, I used the trig identity ##\cos(\theta + \pi) = -\cos(\theta)## and got ##\phi = \pi \:\mathrm{rad}## and ##A = 0.32\:\mathrm{m}## (rounded to 2 sig figs), as well as ##\omega = 6.9\:\mathrm{rad/s} , T = 0.91\:\mathrm{s}, f = 1.1\:\mathrm{Hz}##. Is my use of trig identities, and the value for ##\phi## correct?
Does it matter that I used ##\cos(\theta + \pi) = -\cos(\theta)## instead of the one you suggested?
Yubsicle said:
Is my use of trig identities, and the value for ϕ correct?
Yes.
No, that's fine.
Thanks to everyone for taking the time to help.
