MHB Simple Harmonic Motion: 5kg Particle Suspended by 500 N/m String
A 5 kg particle suspended by a 500 N/m elastic string exhibits simple harmonic motion when pulled down 20 cm from its equilibrium position and released. The elastic force is proportional to the displacement from the equilibrium, confirming the motion's harmonic nature. The equilibrium condition shows that the gravitational force equals the elastic force at the equilibrium position. The net force acting on the particle, derived from the elastic force minus the gravitational force, is proportional to the displacement from equilibrium. Thus, the particle's motion can be classified as simple harmonic motion.
markosheehan
A particle of mass 5 kg is suspended from a fixed point by a light elastic string
which hangs vertically. The elastic constant of the string is 500 N/m.
The mass is pulled down a vertical distance of 20 cm from the equilibrium
position and is then released from rest.
(i) Show that the particle moves with simple harmonic motion.
Mathematics news on Phys.org
Hi markosheehan! ;)
An elastic string provides a force that is linear with the displacement from the rest position.
As a consequence we have simple harmonic motion.
If we want to prove it, we have to set up the equation of motion and solve it.
Care to give it a try?
For the record, we expect some kind of attempt or explanation where you're stuck, if only to figure out how to help you best.
what i tryed to do was find the force down and the force up find the resultant force and let it equal to F=5a and then that would prove it but to do this when i am finding the force in the string i need the natural length of the string but it is not given in the question. to find the force up i use F=k(length-natural length)
We don't need the natural length.
When the string has its natural length, the elastic force is zero.
The elastic force is proportional with the change in its natural length.
So let's start with the position in equilibrium.
Then the force of gravity is equal and opposite the elastic force.
That is:
$$F_g = F_e \quad\Rightarrow\quad mg = k\Delta y \quad\Rightarrow\quad 50 = 500 \Delta y\quad\Rightarrow\quad \Delta y = 0.10 \text{ m}$$
Now initially we pull the mass $20 \text{ cm}$ down and we let go.
Then we have:
$$F_{net} = F_e - F_g = ky-mg = 500y-50 = 500(y-0.10)$$
In other words, the net force is proportional to the distance from the equilibrium position.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
