What Factors Influence Simple Harmonic Motion in a U-Tube?
The discussion focuses on the effects of different liquids and conditions on simple harmonic motion (SHM) in a U-tube. Using oil instead of water does not change the time period, but increased viscosity leads to quicker damping of oscillations. Heating the water causes it to expand, resulting in a longer length of water and an increased time period. The internal diameter of the U-tube can influence the amplitudes of oscillation, with a suggestion to plot the time period against diameter to observe their relationship. Participants are encouraged to provide further insights and confirmations on these points.
4evanaday
These questions are regarding water undergoing SHM in a u-tube.
Q1) What is the effect on the time period and damping in a u-tube when using oil instead of water?
Q2) What is the effect on the time period if the liquid (inside the u tube) is heated?
Q3) How can the internal diameter of the u-tube affect successive amplitudes of oscillations? Devise a suitable experiment.
N/A
Q1) T is unchanged; oil is more viscous so friction between inside of tube is greater thus oscillations die away quickly.
Q2) Heating water makes it expand; length of water increases; T increases.
Q3) I think the ratio between successive amplitudes should be the same... could plotting T against D (diamter) and observing the relationship be sufficient?
Are these right? Can someone please expand on them?
Many thanks.
Bump! Come on guys!
anyone...?
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
