Understanding Momentum Conservation in Particle Collisions
  • Thread starter Thread starter EventHorizon4
    Momentum
In a particle collision scenario, a mass m collides with a stationary mass 2m, resulting in the first mass coming to rest and the second splitting into two equal-mass particles moving at angles. The conservation of momentum must be applied, considering both x and y components of the velocities. The x-component of the momentum before and after the collision must remain equal, while the y-components cancel each other out. This analysis reveals that the speed of each new particle can indeed exceed v/2, aligning with the conservation laws. Understanding the breakdown into components is crucial for resolving the apparent contradiction in speeds.
EventHorizon4
A particle of mass m is moving along the x-axis
with speed v when it collides with a particle of
mass 2m initially at rest. After the collision, the
first particle has come to rest, and the second
particle has split into two equal-mass pieces that
move at equal angles q > 0 with the x-axis.
What is true about the speed of the new particles?
conservation of momentum:
mv = mv
According to the answer, each new particle moves with a speed greater than v/2. This seems to violate conservation of momentum to me...but as most people get this question right, I'm probably missing something obvious...
Ok, so conservation of momentum, m1v1 + m2v2 = m1v'1 + m2v'2. Let's call m1 the mass that hits and m2 the mass initially at rest. Since the target is initially at rest and after collision the mass that m1 is at rest, our equation reduces to: m1v1=m2v'2
v'2=(m1/m2)*v1, and since m2=2*m1. v'2 = (1/2)*v1
According to the answer, each new particle moves with a speed greater than v/2. This seems to violate conservation of momentum to me...but as most people get this question right, I'm probably missing something obvious...[/QUOTE]
Before collision total momentum is mv. (It is rigt)
After collision , 2m split 2 particle into equal mass m but moving at equal angles q > 0 with the x-axis.
Let say after collison velocity V'. You must divide 2 componets for each particle and consider for x components. Use law of conservation of momentum for x-axis , find V' then think!
got it. I'm dumb haha.
yeah you have to break in into components because the x components together add to the initial.. the y components cancel each other out. This is why v > 1/2v
