Simple Piston-Cylinder Problem: problems with finding x and other information.
  • Thread starter Thread starter WtKemper
    Information
The discussion revolves around a thermodynamics problem involving a piston-cylinder device containing water at a specified pressure and volume. The user is attempting to determine the final temperature and power of an electric resistor after the volume doubles due to heating. They have calculated initial and final specific volumes and are considering energy equations to relate electric work and changes in internal energy or enthalpy. The user is unsure how to proceed with finding the temperature and the quality of the mixture, while also questioning the assumption of constant pressure during the process. The conversation emphasizes the need for clarity in applying thermodynamic principles and utilizing steam tables for accurate results.
WtKemper
An insulated Piston-Cylinder device contains .6kg of H20 at 600kPa Initially the volume of the system is .6m3. Now an electric resistor is placed in the tank and turned on for 10 minutes until the volume doubles.
Show this on a T-v diagram
What is final temp?
What is the power of the resistor?
Ein-Eout=(Delta)E
I began using Volume1=.6 m3 Volume2=1.2 m3. so then specific volume for initial = .1 m3/kg and for final specific volume = .2 m3/kg
I know that you can apply the equation above in some way. I'm just unsure how. My first thoughts were Welectric-Workboundary=(delta)U from here can you change this to Welectric=(delta)U-Workboundary=(delta)Enthalpy?
Both are within the range of specific volumes at the Pressure given so I know that it is a Saturated Mixture. But I'm stuck on where to go from here.I know that you have to figure out the ratio of the mixture, but I'm unsure what to use to find this. Any way enough rambling Thank you in advance! I would prefer help more than just answers
Oh I figure I can solve for x by using x= (v-vf)/vfg but I still don't understand how to find temp.
Also can pressure be condsidered constant in this case?
Anyone offer any help? sorry to bump so quickly
I think you are superheated. State 1 has a specific volume of 1 m^3/kg if the mass of water in the cylinder is 0.6 kg. You can find T1, U1 etc. from steam table. Since the piston is allowed to float it looks like you have a constant pressure process from state 1 to 2 so you can find T2, U2 etc.
