Understanding the Concept of Open and Closed Sets in Topology
  • Thread starter Ka Yan
  • Tags
    Sets
In summary: Also, [0, 1] is neither open nor closed.In summary, the main difference between the two assertions is that one implies the set is both open and closed, while the other implies that the set is neither open nor closed. In the real line with its usual topology, the only examples of sets that are both open and closed are the empty set and the entire real line itself. However, in arbitrary topological spaces, there may be more examples of sets that are both open and closed. On the other hand, there are many examples of sets that are neither open nor closed, such as [0, 1) in the real line with its usual topology.
Ka Yan
27
What's the difference between those assertions:
" A set X is both open and closed."
and
" A set X is neither open nor closed."
For the first, I knew some examples: The real line itself, and the empty set.
But what example can be araised about the second?
And any better ones to the former?
Thx.
Mathematics news on Phys.org
and
Those two statements are complete opposites!
If you're working strictly in the real line with its usual topology, there are no other examples of sets that are both open and closed. Can you try to prove this? And as for sets that are neither open nor closed, what can you say about something like [0,1)?
On the other hand, if you work with arbitrary topological spaces, then the situation is different. For example, in any discrete space, every set is both open and closed.
Actually, it is much easier to find examples of sets, in the real line, that are neither open nor closed, than both open and closed. In the real line with the "usual" topology, the only sets that are both open and closed are the empty set and R itself while, as morphism said, any "half open" interval, [a, b) or (a, b], is neither open nor closed.
1. What is a set?
A set is a collection of distinct objects or elements that are grouped together based on a common characteristic or property.
2. How is a set represented?
A set can be represented in various ways, including using curly braces { } to enclose the elements, using set-builder notation, or using a Venn diagram to visually show the elements and their relationships.
3. What is the cardinality of a set?
The cardinality of a set refers to the number of elements in the set. It can be represented by the symbol |S|, where S is the set. For example, if a set has 5 elements, its cardinality would be |S| = 5.
4. What is the difference between a set and a subset?
A subset is a set that contains only elements that are also in another set, known as the superset. In other words, all the elements in a subset are also present in the superset, but the superset may have additional elements that are not in the subset.
5. How are sets used in mathematics?
Sets are used in various mathematical concepts and operations, such as logic, algebra, and probability. They allow for the organization and classification of data, as well as the comparison and manipulation of different groups of objects or elements.
  • Topology and Analysis
