Simple RC and RL Transfer Functions
  • Thread starter Thread starter tastypotato
    Functions Rc
The discussion centers on determining the cutoff frequency of a given transfer function, TF = 200/(1 + j0.001w), which represents a low-pass filter. The cutoff frequency in radians per second is found to be 1000 rad/s, translating to approximately 159.15 Hz. The process involves identifying the poles of the transfer function by setting the denominator to zero. Understanding the physical significance of this cutoff is crucial, as it indicates frequencies above this point will be significantly attenuated. The conversation highlights the importance of grasping transfer function concepts for analyzing filter behavior.
tastypotato
[Solved] Simple RC and RL Transfer Functions
Given the transfer function:
TF= (200)/(1 + j0.001w)
a. Determine the cuttoff frequency in radians per second and in hertz
There are a couple other equations like this in the book, but I just don't grasp the concept or the formulas that the book offers which looks like TF(w)= Vout/Vin = A < Theta degrees.
TF= Vout/Vin = 200 / (1 + j0.001w) --> converted to rectangular form
(200 < 0)/(1 < .057) = 200 < -.057
Which I know is horribly wrong, but these formulas just don't make sense to me. :/
Figured it out and did some deeper reading online, came up with:
Wc= 1/t
Where in the equation TF=200/(1+j.001w), t=.001
So, 1/.001 = 1000
Then you take Wc/(2*pi)
Which then gives you 159.15 Hz
Looks like you've already answered your own question, but I thought I'd elaborate...
To find the corner frequencies of a transfer function (incidentally, the transfer function you give is that of a low-pass filter--Wikipedia for it), you just have to find its poles ('w' which make the denominator go to zero).
In this case, you just set 1+0.001j*w to zero, and determine that w_c is 1000j, which you interpret as 1000 rad/s, or with the formula that w_c = 2*pi*f_c, 159 Hz. (Technically, it should be when the magnitude of the transfer function goes to zero, which gives you the two poles at +/-1000j, and hence, a real frequency of 1000 rad/s).
What is the physical significance of this divide by zero? (Assuming you haven't taken any complex analysis courses)--the system's 'quirks' emerge and have a significant impact (in the case of a low-pass filter, that frequencies higher than the cut-off get significantly attenuated or, cut-off, so to speak). Yes, yes, this is an idealized view of things, but it does give you significant useful information.
