Simple spherical quantum mechanics question: r dot p
The discussion centers on the equation relating the position vector and momentum operator in spherical coordinates, specifically the expression \(\vec{r}\cdot\vec{p} = -i\hbar r \frac{\partial}{\partial r}\). Participants clarify that this relation holds true when considering the momentum operator in the context of spherical coordinates. The equation is derived from the dot product of the radial position vector and the momentum operator, confirming its validity through mathematical manipulation. It is suggested to verify the consistency of this equation with the context provided in lecture notes and other resources. Understanding this relationship is crucial for grasping concepts in quantum mechanics.
zhaos
Maybe I missed it, but in my notes and also in documents like (http://ocw.mit.edu/courses/physics/...all-2013/lecture-notes/MIT8_05F13_Chap_09.pdf) (equation 1.64), I see
$$ \vec{r}\cdot\vec{p} = -i\hbar r \frac{\partial}{\partial r} $$
Where ##r## is the radial distance. Why is this relation true?
$$ \vec{\nabla_r} = (\frac{\partial}{\partial r}, \frac{1}{r}\frac{\partial}{\partial \theta}, \frac{1}{r \sin \theta}\frac{\partial}{\partial \phi}) $$
So is ##\vec{r}\cdot\vec{p}## simply
$$ (r, 0, 0) \cdot -i\hbar\vec{\nabla_r} = -i\hbar r \frac{\partial}{\partial r} $$
Well done.
You should verify by context... is this consistent with what the notes and documents are trying to tell you?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
