Simple wuestion about the sign(+/-) in a momentum conservation problem
In the momentum conservation problem, the confusion arises regarding the sign of the recoil velocity, represented as +w instead of -w. The discussion highlights that if w is considered a positive scalar, it should indeed be negative due to the recoil direction being in the negative x direction. However, treating w as a vector could justify the positive sign, as the diagram indicates w pointing negatively. This inconsistency in vector representation versus scalar notation creates confusion in the equation. Clarifying the treatment of w as either a scalar or vector is essential for accurate momentum conservation analysis.
vande060
http://s861.photobucket.com/albums/ab174/alkaline262/?action=view&current=momentum.jpg
why is it + w instead of -w, it seems like it sould be negative because the recoil velocity is in the negative x direction
you have to admit that is a ms paint masterpiece :D
Yeah, if w is a positive number, then it should be negative.
They might have been treating w as a vector (in this case, you would use +w since the diagram shows w pointing in the negative x direction) but then that equation isn't really consistent since they're not all expressed as vectors.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
