nobahar
- 482
- 2
Express
\frac{1+\sqrt{2}}{3-\sqrt{2}} as a+b\sqrt{2} where a and b are rational numbers.
I started by
\frac{1+\sqrt{2}}{3-\sqrt{2}} * \frac{3+\sqrt{2}}{3+\sqrt{2}}
But, I obtain
\frac{5}{7}-\frac{4}{7}\sqrt{2}
I believe that, here, a and b are rational, but is there a more tidy version? I tried playing with the square root so that it is a multiple of 2, so that I could 'split' it into two square roots, on of the square root of two so that I could use it to cancel out the square root of two on the bottom, then I could also remove the other square root if it was a rational square root. For example, I tried:
\frac{1+\sqrt{2}}{3-\sqrt{2}} * \frac{x+\sqrt{8}}{x+\sqrt{8}}
because
\sqrt{8}= \sqrt{2*4} = \sqrt{2} * \sqrt{4} = 2\sqrt{2}
I haven't specified x, since its just an example. I actually tried making a relationship between x and the square root I introduced, since I could represent it algebraically as
\sqrt{g}
where g is a multiple of two, would give
\sqrt{2}*\sqrt{\frac{1}{2}g}.
I'm guessing its more straight forward than this.
Thanks in advance.
I started by
But, I obtain
because
\sqrt{g}
Thanks in advance.
