Simpson's rule can solve cubics exactly
  • Thread starter Thread starter zeta101
zeta101
Simpson's rule can solve cubics exactly...(as well as quadratics which makes sense) the question is why? I've googled around and can't find an explanation, although it is just stated as being true.
Can someone offer and explanation or a website?
Thanks
The most straightforward way to try and prove it would be to apply Simpson's rule to a generic cubic. (i.e. ax^3 + bx^2 + cx + d)
Thanks for the reply.
Could you tell me that if the integral is from x_0 to x_0 + 2h then can i set x_0 = 0 and it still be a proof (it's a lot simplier if i do)? or have i lost generality?
Thanks again!
Instead of simply wondering if it's okay, you could try and prove it's okay. Can you find a way to convert the general problem into this form?
having thought about it this is the only thing i can think of:
int_{x_0}^{x_0+2h} -----> int_{x_0 -x_0}^{x_0+2h-x_0}
so, that's saying that the integral doesn't lose any generality by subtracting x_0 (a constant) from both the upper and lower limits (i don't know for certain i can do this, but it seems ok). So if it still stays general then setting x_0 to zero is also.
please tell me i am right :)
thanks for the guidance
You only need to prove that appling simpsons rule to x^3 gives the same answer as integration.
Thi
It should be clear that if simpsons works for both polynomials p(x) and q(x) then it works for p(x)+ q(x). Because int (p(x)+q(x)) = int(p(x)) + int(q(x))
and the same rule applies to Simpsons rule since using simpsons rule on the function p(x) +q(x) gives area =( b-a)/6*( p(a)+ q(a) +
4*(p(a+b)/2)+ q((a+b)/2) + p(b) + q(b)).
