Simultaneous Equations: Solving [eq2] and Plugging into [eq1]
  • Thread starter Thread starter camino
The discussion focuses on solving two simultaneous equations involving complex numbers, specifically [eq1] and [eq2]. The user successfully manipulates [eq2] to express Vb in terms of Va but struggles with combining fractions in [eq1] due to the presence of imaginary numbers. Suggestions include finding the least common multiple (LCM) of the fractions, though the user encounters difficulties with their calculator. An alternative approach is proposed to convert complex numbers from polar to rectangular format, allowing for easier manipulation of real and imaginary parts. The conversation emphasizes the importance of clarity in handling complex equations and suggests a method to simplify the problem.
camino
[eq1]: (Va-Vb)/(2i) = {[Vb-(10<0)]/(4-8i)} + {(Vb)/(6i)}
[eq2]: (Va-Vb)/(2i) = (8<20) - Va
Note: < is angle
Solving [eq2]
(Va-Vb) = 2i[(8<20) - Va]
(Va-Vb) = (2i)(8<20) - (2i)(Va)
-Vb = (2i)(8<20) - (2i)(Va) - Va
Vb = -(2i)(8<20) + (2i)(Va) + Va
Vb = -(16<110) + (2i)(Va) + Va
Then plugging into [eq1]
[Va + (16<110) + (2i)(Va) + Va]/[2i] = {[-(16<110) + (2i)(Va) + Va - (10<0)]/[4-8i]} + {[-(16<110) + (2i)(Va) + Va]/[6i]}
[2Va + (16<110) + (2i)(Va)]/[2i] = {[-(16<110) + (2i)(Va) + Va - (10<0)]/[4-8i]} + {[-(16<110) + (2i)(Va) + Va]/[6i]}
I am stuck at this point. If I could find the LCM of the the 2 fractions on the right and add them together I would be fine, but since there are imaginary numbers I'm not sure if that's even possible. (I tried using the lcm feature on my TI-89, didn't work).
Or if there's a better way to solve this please let me know. Thanks.
Note: < is angle
Solving [eq2]
Perhaps it can be solved in that polar format for the complex numbers, but I would find it easier to solve it in rectangular format. That is, convert each complex number from "magnitude>angle" format into A+jB format. Then to solve, the real parts have to be equal, and the imaginary parts have to be equal. You can convert it back to polar form in the end, if that's the format that the complex number answer is supposed to be in.
9K
