MHB Solving Simultaneous Equations: x⁴-y²-xy=4-√15, x³+y³-3x=5√5
The discussion focuses on solving the system of equations x⁴ - y² - xy = 4 - √15 and x³ + y³ - 3x = 5√5. The original poster attempted a trigonometric approach but found it unproductive, leading to a reformulation of the equations using tangent substitutions. Graphical analysis suggests that the blue graph approximates the line x + y = 0, while the brown graph resembles parabolas y = ±x², indicating limited intersection points. A crossing point in the positive quadrant was identified at x = √3 and y = √5, but the location of the other intersection remains uncertain. Further exploration of the second intersection point is anticipated.
anemone
MHB
POTW Director
Hi MHB,
I hope to gain some insights on how to solve this system of equations because I tried it many times to use trigonometric approach but to no avail...:mad:
Problem:
Solve the system of equations
$x^4-y^2-xy=4-\sqrt{15}$
$x^3+y^3-3x=5\sqrt{5}$
Attempt:
At first glance, $x^3-3x$ suggests the substitution of $x=\tan p$ so that $x^3-3x=\tan^3 p-3\tan p=(3\tan^2 p-1)(\tan 3p)$
and the second given equation can be rewritten as below, if we also let $y=\tan q$,
$x^3-3x=5\sqrt{5}-y^3$
$(3\tan^2 p-1)(\tan 3p)=5\sqrt{5}-\tan^3 q$
$\tan^3 q=5\sqrt{5}-(3\tan^2 p-1)(\tan 3p)$
and the first equation becomes
$\tan^4 p-\tan^2 q-\tan p \tan q=4-\sqrt{15}$
$\tan^2 q+\tan p \tan q+4-\sqrt{15}-\tan^4 p=0$
Even if I solve the equation above for $\tan q$ by the quadratic formula, I can see that this is of a futile attempt...
Could someone please help me to solve this very hard problem for me? Thanks in advance.:o
Mathematics news on Phys.org
[graph]pqglddsffo[/graph] (Click on the diagram for an enlargement.)
The brown graph shows the first equation and the blue graph shows the second one. As they go off to infinity, the blue graph approximates the line $x+y=0$ and the brown graph approximates the parabolas $y = \pm x^2$. So I doubt whether there can be any solutions apart from the two crossing points in the diagram. The crossing point in the positive quadrant occurs when $x=\sqrt3,\ y=\sqrt5$ (obtained by guesswork!). I do not see how to locate the other crossing point.
Thank you for this wonderful insight, Opalg! I will try to find the other intersection point and of course will add to this thread if I have found it.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
