Simultaneously unitarily diagonalizeable matrices commute
  • Thread starter Thread starter bmanbs2
    Commute Matrices
bmanbs2
Matrices A and B are simultaneously unitarily diagonalizeable. Prove that they commute.
As A and B are simultaneously unitarily diagonalizeable, there exists a unitary matrix P such that
P^{-1}AP = D_{1} and P^{-1}BP = D_{2}, where D_{1} and D_{2} are diagonal matrices., where D_{1} and D_{2} are diagonal matrices.
Diagonal matrices always commute.
A unitary matrix multiplied by its conjugate transpose results in an identity matrix.
So far I have that
P^{-1}APP^{-1}BP = P^{-1}ABP = D_{1}D_{2} and
P^{-1}BPP^{-1}AP = P^{-1}BAP = D_{2}D_{1}
D_{1}D_{2} = D_{2}D_{1} P^{-1}ABP = P^{-1}BAP.
Is this enough to show that AB = BA? Where would I use the fact that P is unitary?
Also, how do I delete the latex part at the top? It goes straight to the first latex entry. I put empty tex tags at the top to make it as non-distracting as possible, but if I don't add them, the gibberish goes straight to the next latex section.
Bump?
you don't need the unitary part, since two diagonalizable matrices are generally simutaneously diagonalizable if and only if they commute; the unitary part is needed if you also assert that the matrices are both normal -- did you leave that out?
I didn't, but I just recieven an update to the assignment that says I need to show the matrices are normal.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
