Solve Slope Intercept Equations: (2,1), 4x-2y=3
  • Thread starter Thread starter mistalopez
    Slope
To solve for the slope-intercept forms of lines through the point (2,1) that are parallel and perpendicular to the line given by the equation 4x-2y=3, first convert the line to slope-intercept form, yielding y=2x-3/2. For the parallel line, maintain the same slope of 2, and using the point (2,1), the y-intercept can be calculated, resulting in the equation y=2x+whatever b is. For the perpendicular line, use the negative reciprocal of the slope, which is -1/2, and again find the y-intercept using the point (2,1). This method is noted to be quicker than using the point-slope formula for determining the equations.
mistalopez
Write the slope intercept forms of the equation of the lines through the given point (a) parallel to the given line and (b) perpendicular to the given line.
Point: (2,1) Line: 4x-2y=3
y-y1=m(x-x1)
y=mx+b
I first put the line into slope intercept form: y=-2x+(3/2)
a) Next, I used point-slope to get the parallel line:
y-y1=m(x-x1)
y-1=-2(x-2)
y-1=-2x+4
y=-2x+5
*However, the correct answer should be y=2x-3
b) I used the reciprical of the slope to make it perpendicular: m = 1/2
Next I used the point-slope to find the perpendicular line of the equation.
y-y1=m(x-x1)
y-1=(1/2)(x-2)
y-1=(1/2x)-1 *Multiply both sides by 2 to remove fraction
2(y-1)=((1/2x)-1)2
2y-2=1x-2
2y=1x
y=1x/2
*However, the correct answer in the book is y=(-1/2x)+2
What am I doing wrong?
it should be y = 2x - 3/2, you'll probably get the right answer with that
Conveniently, one doesn't even have to use the point slope formula to solve this problem. By simply knowing that parallel lines have the same slope and perpendicular lines have a negative reciprocal slope and using the slope-intercept equation will yield you the proper result. For instance:
The slope intercept form of 4x - 2y = 3 would be:
y = 2x - 3/2
For the parallel line, one would know that the slope must be the same as the given, thus, in this case, the slope would be 2. By using the given points, (2,1), one can determine the y-intercept of the parallel line like so:
1 = 2(2) + b
and solve for b.
The equation for the parallel line would then be y = 2x + whatever b would be.
The perpendicular line's equation is determined just the same. By knowing that the slope of a line perpendicular to the given is a negative reciprocal, one will see that the slope in this case would be -1/2 and thus:
1 = -1/2(2) + b
and solve for b once more.
I've always found this method quicker and easier for me than using the point-slope equation. Hopefully it will help you.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
