Finding the Best Pump for Nickel Slurry Transport
In summary, the conversation discusses the need for a pump that can transport a nickel slurry with specific flow rate, density, and temperature. The recommended pump is a medium duty slurry centrifugal pump with a flow rate of 0.022m3/s and a required hydraulic power of 2.7kW with safety factor. Schur Pump Company, established in 1975, is suggested as a manufacturer and repairer of pumps for abrasive and corrosive applications. Their Schurco Slurry Pump is considered the best and most cost-effective option.
sdlee
hi guys.
I need some basic information about a pump that will be able to transport a nickel slurry up around 1-2m high. the mass flow rate of the slurry is 27 kg/s with a density of 1218 kg/m^3. the temperature of the slurry is 25 deg c.
What is the best type of pump to use in this instance? what sort of power requirement will it have? what does a pump like this cost?
thanks in advance.
U require a medium duty slurry centrifugal pump for your application.
The most basic reqs to size a pump are flowrate & pressure head.
In your case FLOWRATE =27kg/s/1218kg/m3 = 0.022m3/s.(79.2m3/hr)
Your HEAD = 1-2m + (friction head) + discharge pressure (im metres)
if the discharge line is short and you discharge at atm pressure, your head may come to 10-15m.
In which case Hydraulic Power reqd = FLOW (m3/s) * Head (Pa) = 0.022 * 10 *1218 *9.8 = 2.7kW
Place some safety factor (on the motor size ONLY)
Look at a manf curve book to find the pump meeting your specs.
The proper way to size slurry pumps however is much more complex than this. U mus consider NPSH, head derating, viscosity, pipe friction etc.
thanks for the answer.
Appreciated.
Steve.
Located in Jacksonville, Florida and established in 1975, Schur Pump Company has been manufacturing and repairing pumps for over 30 years. Our vision is to be a key force in providing cost effective high quality new pumps, re-manufactured pumps, pump parts, pump repairs, pump solutions and customer support for abrasive and corrosive applications.
When you evaluate a Schurco Slurry Pump based on all the criteria, you find that it is the best and least expensive pump to use.
http://www.schurcoslurry.com
Hello,
Thank you for your inquiry about finding the best pump for nickel slurry transport. Based on the information provided, a centrifugal pump would be the most suitable choice for this application. Centrifugal pumps are commonly used for handling slurry due to their ability to handle high flow rates and abrasive materials.
In terms of power requirement, a pump with a motor power of approximately 30 kW would be sufficient for your specified flow rate and head height. However, this may vary depending on the specific design and efficiency of the pump.
As for cost, the price of a centrifugal pump can range from a few hundred dollars to several thousand dollars, depending on the size, materials, and features of the pump. It is best to consult with a pump supplier or manufacturer for a more accurate cost estimate.
I hope this information helps in your search for the best pump for nickel slurry transport. If you have any further questions, please do not hesitate to reach out. Best of luck with your project.
Sincerely,
Related to Finding the Best Pump for Nickel Slurry Transport
1. What factors should be considered when selecting a pump for nickel slurry transport?
When selecting a pump for nickel slurry transport, some important factors to consider include the viscosity and density of the slurry, the required flow rate and pressure, the distance the slurry needs to be transported, and the type of pump that is most suitable for handling abrasive materials.
2. What type of pump is best for transporting nickel slurry?
The best type of pump for transporting nickel slurry is a centrifugal pump. This type of pump is designed to handle abrasive materials and can provide high flow rates and pressure, making it ideal for transporting slurry over long distances.
3. What are the potential challenges in pumping nickel slurry?
Some potential challenges in pumping nickel slurry include the high viscosity and density of the slurry, which can cause issues with clogging and wear on pump components. The abrasive nature of the slurry can also lead to increased maintenance and replacement costs for pump parts.
4. How can I ensure the longevity of the pump when transporting nickel slurry?
To ensure the longevity of the pump when transporting nickel slurry, it is important to select a pump that is specifically designed for handling abrasive materials. Regular maintenance and monitoring of the pump's performance can also help to identify any potential issues before they become major problems.
5. Are there any alternative methods for transporting nickel slurry besides using a pump?
While using a pump is the most common method for transporting nickel slurry, there are some alternative methods that can be considered. These include using air-powered diaphragm pumps, slurry pipelines, or pneumatic conveying systems. However, these methods may have their own limitations and should be carefully evaluated before making a decision.
  • Materials and Chemical Engineering
  • Mechanical Engineering
15K
