When does the small angle approximation deviate by more than 1%?
The discussion focuses on determining the angle at which the small angle approximation deviates from the exact trigonometric result by more than 1%. The relevant equations are the approximate formula d = rθ and the exact formula d = 2*r*Sin(θ/2). The user attempts to set up an equation to find θ, using the condition |Exact - Approx.|/Exact = 0.01, leading to (θ/2)*Csc(θ/2) = 1.01. It is noted that this equation can only be solved numerically or graphically, and there is a reminder to convert the angle into degrees. The discussion emphasizes the need for numerical methods to isolate θ accurately.
Airsteve0
Find, by comparison with exact trigonometry, the angle,  (provide a numerical value
in degrees), above which the small angle approximation departs from the exact result by more than 1 percent.
Approx.: d = s = rθ
Exact: d = 2*r*Sin(θ/2)
.01 = |Exact - Approx.|/Exact
At this point I am unsure of how to isolate for θ. Any tips are greatly appreciated, thanks!
Approx.: d = s = rθ
That equation can only be solved numerically or graphically.
Don't forget to change the angle to degree measure.
