JavaScript Snake size not increasing after eating food
  • Thread starter Thread starter shivajikobardan
    Food Increasing
The discussion centers around a coding issue where a snake game's size does not increase after the snake "eats" food. The initial code snippet checks for the snake's coordinates against the food's position but fails to properly update the snake's size. Participants emphasize the importance of organizing state variables into a single object for clarity and efficiency. They suggest that the coordinates for the new segment of the snake should reflect its position before it moves, rather than simply duplicating the last segment's coordinates. There is a strong advocacy for self-debugging and understanding code logic rather than seeking direct solutions, as this fosters better learning. Additionally, there are critiques of the original poster's code and the need for a clearer reproduction of the problem, as some users found the provided code insufficient for troubleshooting. The conversation also touches on the challenges of finding appropriate programming exercises for skill development.
shivajikobardan
TL;DR Summary
snake game javascript
Relevant code:
JavaScript:
if (food.x === snake[0].x && food.y === snake[0].y) {
    // increase the size of the snake
    snake.push({
      x: snake[snake.length - 1].x,
      y: snake[snake.length - 1].y    });
where snake is an array of objects. Each object is x and y coordinates of snake position and food is an object with x and y coordinates randomly placed.
Here's the full code:
Technology news on Phys.org
First I strongly encourage you to stop scattering variables representing state around in your code (e.g. let d half way down). Gather all of these into a single object declared before anything else:
JavaScript:
const state = {
  // Current direction of the snake (could have a better name like `currentDirection`).
  d: 'right',
  // Array of coordinates of the elements of the snake.
  snake: [{ x: 15, y: 15 }],
This will save you a LOT of time, but more importantly it will also save time for anyone else trying to help you.
Now as to your question think about where you want the coordinates of the new element to be after eating food to be. Then look at x: snake[snake.length - 1].x and think where you are actually setting the coordinates to be.
Likes Wrichik Basu and Vanadium 50
@pbuk just humble request, is it illegal to share the code in this forum or something? I've tried a lot and failed. So, would not it be good to share the code with me now? Or is stackoverflow the only place?
Those who are willing to learn will still learn even if you share code, those unwilling to learn won't even if you don't. Not sharing code in a programming problem where someone has gave that much try is just funny.
  • Skeptical
Likes Wrichik Basu
You are asking us to correct the logic of your program. Well and good. We can help with that, and @pbuk did help with that:
Now, you are basically expecting to be spoon-fed the correct version of the code instead of being given hints where to find the issues. This is something we prefer not to do. In my personal opinion, in the case of programming, you will learn a lot more by debugging your code yourself with occasional hints from others rather than someone just giving away the full code with necessary changes made, unless the error is not logical but syntactical. That's how I learnt programming myself.
Likes Vanadium 50, DrClaude, Mark44 and 1 other person
looks like I should be paying to a tutor instead :D thanks for your responses.
  • Skeptical
Likes Vanadium 50
btw stackoverflow and chatgpt both thinks the code should be working. I also don't see anything wrong with the code even though I've read your comments.
Thread title: Snake size not getting increased after eating food
Whether you see it or not, the thread title you chose indicates that you know something is wrong with the code. The fact that ChatGPT and some random users on stackoverflow think that the code should be working does not reflect well on them.
This is a very strong hint.
I couldn't agree with this more. Seeing someone do something and doing the same thing yourself are two entirely different things. And to elaborate, one aspect of effective debugging is to predict beforehand what some section of code will produce, and then using the debugger to verify that prediction or tell you that for some reason, your prediction was incorrect.
Likes Wrichik Basu
ChatGPT is not even supposed to check your code.
I found your question on Stack Overflow: https://stackoverflow.com/q/75368306/8387076
One user commented that it works for them. They posted a link, where I see just a white screen. No HTML, no CSS and only some JS. A white screen. No snake. No boxes. Doesn't even make sense.
The MWE you posted on SO isn't even enough to reproduce what you are trying to do.
Also, there is a difference between "should be working" and "is working".
From the output of the code sample you posted in the OP, I can confirm it's not working, even though I am illiterate in JS. In addition to the fact that the snake size doesn't increase, if the snake goes out of the boundary, it never returns.
If everything is fine, why post a thread here and a question on SO?
chatgpt
I use fortune cookies. Tasatier and no less reliable.
  • Haha
Likes fresh_42, Wrichik Basu and Tom.G
The code has a few problems.
First, you only ever move the first segment of the snake. And second, when you grow the snake, you need to add the new segment to the position where the last segment was before it moved. And then what happens if the snake goes out of bounds or self intersects?
You might try to get some paper and pencil and draw the snake, and then try to think through what things should happen step by step when it updates. Then maybe try putting those steps in comments first, and then carefully add the code to implement the steps.
Here is an example with pseudocode of how your draw function could work, if you get stuck:
One way to think about it: move each non head segment to the position of the segment in front of it, move the head segment in the current direction, and if it eats food, add a new segment where the last one used to be.
Code:
// save last segment position before moving it
lastSegPrevious = segments.last
// move each non-head segment to the position of the segment in front of it
for( i = N-1; i >= 1; --i)
    segments[ i ] = segments[ i - 1 ]
// move the head in the current direction
segments[ 0 ] = += d
// What if it goes out of bounds?
// check if snake eats food
if segment[ 0 ] == foodPos
    // add new segment where the last segment used to be
    segments.push( lastSegPrevious )
// Self intersection?
draw everything
  • Care
Likes Wrichik Basu
@Wrichik Basu impressed by your stuffs(apps and github). Would love to hear how you achieved this? How do you achieve problem solving logic?
Code:
segments[ 0 ] += d
draw everything
thanks for the good stuff.
My school gave a hell LOT of programming problems. And I solved them all by myself. That created the base for programming logic.
Likes Dale and Jarvis323
Can you share those problems? I'm having hard time findin problems that are not too easy and not too hard. Codewars 7kyu problems are even harder for me. Indian programming books don't have proper exercises.
Those are Java programs, but anyway, I will get in touch with you via PM after I polish the document a bit.
