Discovering the Solar Corona Luminosity Curve: Explained and Explored
The discussion centers on determining the solar corona luminosity curve in relation to distance, noting that the corona can be observed up to 4 solar radii. The curve is described as approximately exponential, but the exact equation is sought. A reference to a figure from a specific document suggests a temperature range of about 1,500,000 K for the corona, indicating that the highest luminosity value could be ten times the lowest. The relationship between temperature and luminosity is highlighted using the equation L=4π(R^2)σ(T^4), leading to a conclusion that the difference in luminosity could be calculated by multiplying the lowest values by 10^4. Clarification on the accuracy of this approach is requested.
Eleftheria
I've been trying to find out what's the curve for the solar corona luminosity vs distance like.
I know that the corona can be practically observed up to 4 solar radii. I also found out that the curve is more or less exponential but I need the actuall equation of the curve.
Can anyone help me?
Astronomy news on Phys.org
Judging by that figure I assume that the difference in temperature (from the lowest to the highest value) for the corona is about 1 500 000 K (more or less), which means that the lowest value must be multiplied by 10 to reach the highest.
So, based on the equation that relates temperature and luminosity [L=4π(R^2)σ(T^4)] I guess the difference in luminosity (from the lowest to the highest value) can be found if we multiply the lowest values by 10^4.
Am I right?
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
